Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement
  1. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Batteries: step 1, image 1 of 1
    • Press down on the two tabs at the top of the door.
    • Rotate the door away from the radio, towards you.
    • Lift the door out of the three smaller tabs on the bottom.
    • Ensure the radio is turned off to avoid the possibility of electric shock.
    • The battery compartment door is not shown.
  2. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Batteries: step 2, image 1 of 3 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Batteries: step 2, image 2 of 3 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Batteries: step 2, image 3 of 3
    • Push the batteries against the spring and pull out using your finger to remove them.
    • To insert the new batteries, push the negative end of the 1st battery against a spring and follow the diagram pictured to insert the batteries in the correct orientation.
  3. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Screws: step 3, image 1 of 3 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Screws: step 3, image 2 of 3 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Screws: step 3, image 3 of 3
    • Remove the 6 screws (30 mm in length) with the Phillips #2 Screwdriver from the large holes marked by arrows on the radio.
  4. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Opening: step 4, image 1 of 1
    • Press the EJECT button to open the cassette deck.
    • Pressing this button is required to allow the front face to separate from the case.
  5. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement: step 5, image 1 of 2 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement: step 5, image 2 of 2
    • Grasp the radio from the front and back halves and gently pull apart to separate them.
  6. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement: step 6, image 1 of 2 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement: step 6, image 2 of 2
    • Pull the white plug out from the red outlet in the Orange circuit board in the back face of the casing.
    • Take care not to break the red outlet off the circuit board.
    • The front and back portions of the casing are now separated from each other.
  7. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Volume or Tone Knob: step 7, image 1 of 2 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Volume or Tone Knob: step 7, image 2 of 2
    • Push upwards against bottom edge of the knob connection with a flat head screwdriver until the knob pops off.
    • You may wish to hold on to the knob so you don't lose it!
3 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 2,986
