Sony CPF-IP001 Buttons on Main Speaker Replacement
  1. Sony CPF-IP001 Buttons on Main Speaker Replacement, Main Speaker Housing Disassembly: step 1, image 1 of 1
    • Remove two 6mm Phillips #0 screws.
    • Remove two 7.5 mm Phillips #0 screws.
    • Remove seven 4 mm Phillips #0 screws.
  2. Sony CPF-IP001 Buttons on Main Speaker Replacement: step 2, image 1 of 3 Sony CPF-IP001 Buttons on Main Speaker Replacement: step 2, image 2 of 3 Sony CPF-IP001 Buttons on Main Speaker Replacement: step 2, image 3 of 3
    • Remove six 4 mm Phillips #0 screws from the metal backing.
    • Remove six 5 mm Phillips #0 screws from the metal backing.
    • Using the plastic opening tool, remove the metal plate from the main speaker by gently pulling on it.
  3. Sony CPF-IP001 Buttons on Main Speaker Replacement: step 3, image 1 of 2 Sony CPF-IP001 Buttons on Main Speaker Replacement: step 3, image 2 of 2
    • Remove the plastic dock cover by using two fingers to push the attached metal piece forward and slide it out of the holes.
  4. Sony CPF-IP001 Buttons on Main Speaker Replacement: step 4, image 1 of 3 Sony CPF-IP001 Buttons on Main Speaker Replacement: step 4, image 2 of 3 Sony CPF-IP001 Buttons on Main Speaker Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Using the plastic opening tool, detach the wires connected to the metal plate
    • When disconnecting the wires, be careful not to pull on the wires themselves. Use the plastic opening tool and the connector to disconnect it.
    • Use the plastic opening tool to remove wires connected to the circuit board on the far right.
    • Use the tweezers to remove wires connected to the circuit board in between the two black wires.
    • Use the tweezers to press the release tab on the front and back of the plastic white wire head.
    • Once the tab is pressed on both sides, lift up to slide wire head out of socket.
  5. Sony CPF-IP001 Buttons on Main Speaker Replacement: step 5, image 1 of 1
    • Remove two 5 mm Phillips #0 screws.
  6. Sony CPF-IP001 Buttons on Main Speaker Replacement: step 6, image 1 of 3 Sony CPF-IP001 Buttons on Main Speaker Replacement: step 6, image 2 of 3 Sony CPF-IP001 Buttons on Main Speaker Replacement: step 6, image 3 of 3
    • Using the metal spudger, loosen the metal cap at the end of the speaker.
    • Slide down the loosened cap to remove it from the end of the speaker.
    • Simultaneously push down on the buttons and slide the speaker out from the casing.
  7. Sony CPF-IP001 Buttons on Main Speaker Replacement, Buttons on Main Speaker: step 7, image 1 of 3 Sony CPF-IP001 Buttons on Main Speaker Replacement, Buttons on Main Speaker: step 7, image 2 of 3 Sony CPF-IP001 Buttons on Main Speaker Replacement, Buttons on Main Speaker: step 7, image 3 of 3
    • Remove two 6 mm Phillips #0 screws.
    • Gently lift the silver buttons up to remove.
  8. Sony CPF-IP001 Buttons on Main Speaker Replacement: step 8, image 1 of 3 Sony CPF-IP001 Buttons on Main Speaker Replacement: step 8, image 2 of 3 Sony CPF-IP001 Buttons on Main Speaker Replacement: step 8, image 3 of 3
    • Using the plastic opening tool, disconnect the white connector from the circuit board.
    • Replace the broken circuit board with a new one.
3 other people completed this guide.
Cole Stanley
290 Reputation
1 Guide authored
Cal Poly, Team 6-14, Maness Spring 2015 Member of Cal Poly, Team 6-14, Maness Spring 2015
CPSU-MANESS-S15S6G14
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 329
