Sony CPF-IP001 Subwoofer Replacement
  1. Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: step 1, image 1 of 2 Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: step 1, image 2 of 2
    • Remove fourteen 8 mm Phillips #2 screws from the bottom of the subwoofer.
    • Once all of the screws are removed, the cover can be taken off using a metal spudger.
  2. Sony CPF-IP001 Subwoofer Replacement: step 2, image 1 of 2 Sony CPF-IP001 Subwoofer Replacement: step 2, image 2 of 2
    • Remove eight 14 mm Phillips #2 screws holding the circuit board in place.
    • Using the plastic opening tool, carefully remove the circuit board.
    • There will be 3 wires connected to the opposite side of the circuit board. Be careful not to pull the board out of the device too far and damage these wires.
  3. Sony CPF-IP001 Subwoofer Replacement: step 3, image 1 of 2 Sony CPF-IP001 Subwoofer Replacement: step 3, image 2 of 2
    • Remove the first of the three wires by squeezing the clip and pulling it out.
    • After disconnecting the first wire, the two attached wires can be more easily accessed.
  4. Sony CPF-IP001 Subwoofer Replacement: step 4, image 1 of 3 Sony CPF-IP001 Subwoofer Replacement: step 4, image 2 of 3 Sony CPF-IP001 Subwoofer Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the wire furthest to the left by squeezing the clip and pulling it out.
    • Detach the third wire by carefully using the tweezers.
    • The circuit board is now completely detached and can be set aside.
  5. Sony CPF-IP001 Subwoofer Replacement: step 5, image 1 of 2 Sony CPF-IP001 Subwoofer Replacement: step 5, image 2 of 2
    • Remove six 8 mm Phillips #2 screws.
    • Slide the side panel with the power cord out from the housing.
    • The side panel with the power cord will come out as a whole unit with the subwoofer air tunnel.
  6. Sony CPF-IP001 Subwoofer Replacement, Subwoofer: step 6, image 1 of 1
    • Remove two 8 mm Phillips #2 screws holding the side panel in place.
  7. Sony CPF-IP001 Subwoofer Replacement: step 7, image 1 of 1
    • Remove eight 8 mm Phillips #2 screws holding the subwoofer tray to the housing.
  8. Sony CPF-IP001 Subwoofer Replacement: step 8, image 1 of 2 Sony CPF-IP001 Subwoofer Replacement: step 8, image 2 of 2
    • Using a metal spudger, slightly peel back the plastic the has been glued to the tray and the housing.
    • Slide the tray containing the subwoofer out of the housing.
  9. Sony CPF-IP001 Subwoofer Replacement: step 9, image 1 of 2 Sony CPF-IP001 Subwoofer Replacement: step 9, image 2 of 2
    • After removing the tray, flip it over and you will find four screws connecting the subwoofer.
    • Remove four 7.5 mm Phillips #2 screws.
  10. Sony CPF-IP001 Subwoofer Replacement: step 10, image 1 of 2 Sony CPF-IP001 Subwoofer Replacement: step 10, image 2 of 2
    • The subwoofer has now been removed from the device and can be replaced.
3 other people completed this guide.
Mike Bolton
473 Reputation
4 Guides authored
Cal Poly, Team 6-14, Maness Spring 2015 Member of Cal Poly, Team 6-14, Maness Spring 2015
CPSU-MANESS-S15S6G14
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 745
