Sony Clie PEG-NR70 Battery Pack Replacement
  1. Sony Clie PEG-NR70 Battery Pack Replacement, The Case: step 1, image 1 of 1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Battery Pack Replacement: step 2, image 1 of 1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Battery Pack Replacement: step 3, image 1 of 2 Sony Clie PEG-NR70 Battery Pack Replacement: step 3, image 2 of 2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Battery Pack Replacement, Battery Pack: step 4, image 1 of 2 Sony Clie PEG-NR70 Battery Pack Replacement, Battery Pack: step 4, image 2 of 2
    • Pull up on the black tab on the battery pack to reveal the power cord.
  5. Sony Clie PEG-NR70 Battery Pack Replacement: step 5, image 1 of 1
    • Disconnect the battery pack from the motherboard by unplugging the power cables. Gently pull the wire toward the bottom of the device.
    • Be careful to not tear the cables! They are very thin.
  6. Sony Clie PEG-NR70 Battery Pack Replacement: step 6, image 1 of 1
    • Gently peel back the adhesive to completely disconnect the battery pack from device.
3 other people completed this guide.
Courtney
49 Reputation
2 Guides authored
Cal Poly, Team 14-11, Maness Spring 2013 Member of Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Members
8 Guides authored
One Comment
Hi, this is really helpful, thank you.
Richard Hancock - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 32
All Time: 2,230
