Sony Clie PEG-NR70 Memory Module Replacement
  1. Sony Clie PEG-NR70 Memory Module Replacement, The Case: step 1, image 1 of 1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Memory Module Replacement: step 2, image 1 of 1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Memory Module Replacement: step 3, image 1 of 2 Sony Clie PEG-NR70 Memory Module Replacement: step 3, image 2 of 2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Memory Module Replacement, Memory Module: step 4, image 1 of 1
    • Holding the memory module in place, unscrew the three 0.9mm screws with a Phillips #00 screwdriver.
  5. Sony Clie PEG-NR70 Memory Module Replacement: step 5, image 1 of 1
    • Lightly grab the memory module and pull it upwards.
    • Make sure you grab the end closest to the edge of the device. You may have to wiggle the module a bit to get it to come free.
Daniel Soski
57 Reputation
6 Guides authored
Cal Poly, Team 14-11, Maness Spring 2013 Member of Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 554
