Sony Clie PEG-UX50 Rear Case Replacement
  1. Sony Clie PEG-UX50 Rear Case Replacement, Rear Cover Case: step 1, image 1 of 3 Sony Clie PEG-UX50 Rear Case Replacement, Rear Cover Case: step 1, image 2 of 3 Sony Clie PEG-UX50 Rear Case Replacement, Rear Cover Case: step 1, image 3 of 3
    • Use the Phillips #1 screwdriver to remove the four screws from the back of the rear cover.
    • Use the Phillips #1 screwdriver to remove the screw on the right side of the rear cover.
    • Use the Phillips #1 screwdriver to remove the screw on the top of the rear cover.
  2. Sony Clie PEG-UX50 Rear Case Replacement: step 2, image 1 of 2 Sony Clie PEG-UX50 Rear Case Replacement: step 2, image 2 of 2
    • Gently pry the rear cover case off to remove both the USB port cover and the hold switch.
  3. Sony Clie PEG-UX50 Rear Case Replacement: step 3, image 1 of 2 Sony Clie PEG-UX50 Rear Case Replacement: step 3, image 2 of 2
    • Remove the side cover.
    • Slowly pull on the rear cover case to separate it from the rest of the device. The case should not come off completely.
    • To avoid wire breakage, do not pull hard on the speaker connection wire.
  4. Sony Clie PEG-UX50 Rear Case Replacement: step 4, image 1 of 1
    • Gently remove the speaker wire from the device.
    • The rear cover case should now be completely separate from the device.
Christopher M Garcia
26 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 29
All Time: 4,241
