Sony Clie PEG-UX50 Tilt Screen Replacement
  1. Sony Clie PEG-UX50 Tilt Screen Replacement, Tilt Screen: step 1, image 1 of 3 Sony Clie PEG-UX50 Tilt Screen Replacement, Tilt Screen: step 1, image 2 of 3 Sony Clie PEG-UX50 Tilt Screen Replacement, Tilt Screen: step 1, image 3 of 3
    • Take off the screws located on the two sides of the tilt screen.
    • Unscrew the screw located at the tilt base of the screen.
  2. Sony Clie PEG-UX50 Tilt Screen Replacement: step 2, image 1 of 3 Sony Clie PEG-UX50 Tilt Screen Replacement: step 2, image 2 of 3 Sony Clie PEG-UX50 Tilt Screen Replacement: step 2, image 3 of 3
    • Gently remove the back plate of the tilt screen by sliding it upward.
    • With caution, lift the wires from the track in the back plate.
  3. Sony Clie PEG-UX50 Tilt Screen Replacement: step 3, image 1 of 2 Sony Clie PEG-UX50 Tilt Screen Replacement: step 3, image 2 of 2
    • Disconnect the thin USB cable attached to the Integrated Circuit.
  4. Sony Clie PEG-UX50 Tilt Screen Replacement: step 4, image 1 of 2 Sony Clie PEG-UX50 Tilt Screen Replacement: step 4, image 2 of 2
    • Detach the plastic black frame from in between the plate and the LCD.
    • Do not disconnect the display from the board yet.
  5. Sony Clie PEG-UX50 Tilt Screen Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect the thin connector from the face plate using tweezers.
  6. Sony Clie PEG-UX50 Tilt Screen Replacement: step 6, image 1 of 1
    • Quickly release and disconnect the thick cable with your hands.
Follow these instructions in reverse order to reassemble your device.
Rishad R Rai
1 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 2,770
