Sony Cyber-Shot DSC-H1 Lens Replacement
  1. Sony Cyber-Shot DSC-H1 Lens Replacement, Back Panel: step 1, image 1 of 1
    • Power down the camera and remove the batteries.
  2. Sony Cyber-Shot DSC-H1 Lens Replacement: step 2, image 1 of 3 Sony Cyber-Shot DSC-H1 Lens Replacement: step 2, image 2 of 3 Sony Cyber-Shot DSC-H1 Lens Replacement: step 2, image 3 of 3
    • Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
    • There are six 5.22mm long, 3.00mm head diameter screws total.
    • The left side is not shown but there should be 1 screw on that side.
  3. Sony Cyber-Shot DSC-H1 Lens Replacement: step 3, image 1 of 2 Sony Cyber-Shot DSC-H1 Lens Replacement: step 3, image 2 of 2
    • Remove the back casing.
    • The casing itself is sturdy so don't be afraid to remove it forcefully.
  4. Sony Cyber-Shot DSC-H1 Lens Replacement, LCD Screen: step 4, image 1 of 1
    • Take a hold of the right side of the LCD screen and lift it towards the left.
    • The screen is held firm and will require a bit of force to ease it from its housing.
  5. Sony Cyber-Shot DSC-H1 Lens Replacement: step 5, image 1 of 1
    • Unplug the large conductive tape attached to the screen.
    • Remove the LCD from the device.
  6. Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: step 6, image 1 of 2 Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: step 6, image 2 of 2
    • Unscrew and remove the gray backing behind the LCD screen.
  7. Sony Cyber-Shot DSC-H1 Lens Replacement: step 7, image 1 of 3 Sony Cyber-Shot DSC-H1 Lens Replacement: step 7, image 2 of 3 Sony Cyber-Shot DSC-H1 Lens Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Using a Phillips #0 screwdriver, unscrew the four 4.24 mm black screws off the blue panel on the right side.
    • Disconnect the white conductive tape.
    • Remove the blue panel.
    • Use tweezers to remove the three conductive tape strips on the right side.
  8. Sony Cyber-Shot DSC-H1 Lens Replacement: step 8, image 1 of 2 Sony Cyber-Shot DSC-H1 Lens Replacement: step 8, image 2 of 2
    • Use tweezers to remove the orange conductive tape located below the shutter.
    • Unplug the three ZIF connectors from the motherboard.
  9. Sony Cyber-Shot DSC-H1 Lens Replacement: step 9, image 1 of 1
    • Flip up the blue overlapping board at the top.
    • Use tweezers to disconnect the remaining connectors.
  10. Sony Cyber-Shot DSC-H1 Lens Replacement: step 10, image 1 of 1
    • Remove the motherboard and battery pack unit.
  11. Sony Cyber-Shot DSC-H1 Lens Replacement: step 11, image 1 of 3 Sony Cyber-Shot DSC-H1 Lens Replacement: step 11, image 2 of 3 Sony Cyber-Shot DSC-H1 Lens Replacement: step 11, image 3 of 3
    • Use a screwdriver to remove 5 screws on plastic panel.
    • Remove the single screw on the silver panel in the center.
  12. Sony Cyber-Shot DSC-H1 Lens Replacement: step 12, image 1 of 3 Sony Cyber-Shot DSC-H1 Lens Replacement: step 12, image 2 of 3 Sony Cyber-Shot DSC-H1 Lens Replacement: step 12, image 3 of 3
    • Use tweezers to remove the blue control panel.
    • Remove the lens from the camera.
3 other people completed this guide.
Charlie Pugeda
505 Reputation
3 Guides authored
Baylor, Team S5-G4, Williams Spring 2018 Member of Baylor, Team S5-G4, Williams Spring 2018
BU-WILLIAMS-S18S5G4
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 1,680
