Sony Cyber-Shot DSC-TX30 Movie Button Replacement
  1. Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Battery: step 1, image 1 of 2 Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Battery: step 1, image 2 of 2
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: step 2, image 1 of 2 Sony Cyber-Shot DSC-TX30 Movie Button Replacement: step 2, image 2 of 2
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: step 3, image 1 of 2 Sony Cyber-Shot DSC-TX30 Movie Button Replacement: step 3, image 2 of 2
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: step 4, image 1 of 1
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Outer Shell: step 5, image 1 of 1
    • Using a Phillips #00 screwdriver, remove one black 2 2/5mm screw that is located next to the wrist band loop.
  6. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: step 6, image 1 of 1
    • Using the plastic opening tool, separate the edge-casing from the rest of the camera.
  7. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: step 7, image 1 of 2 Sony Cyber-Shot DSC-TX30 Movie Button Replacement: step 7, image 2 of 2
    • Pull the edge-casing off of the camera.
  8. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: step 8, image 1 of 1
    • Using a Phillips #00 screwdriver, remove one silver 3mm screw located on the front side of the camera.
    • Using a Phillips #00 screwdriver, remove one silver 5 2/5mm screw located on the front side of the camera
    • Using a Phillips #00 screwdriver, remove one black 2 1/2mm screw located on the front side of the camera.
  9. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: step 9, image 1 of 1
    • Using a Phillips #00 screwdriver, remove one 2 1/2mm screw located near the wrist strap.
  10. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: step 10, image 1 of 1
    • Using a Phillips #00 screwdriver remove one black 2 2/5mm screw near the tripod slot on the bottom of the casing.
  11. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: step 11, image 1 of 1
    • Using a Phillips #00 screwdriver remove the two 2 2/5mm black screws from the side of the camera opposite of the wrist strap
  12. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: step 12, image 1 of 2 Sony Cyber-Shot DSC-TX30 Movie Button Replacement: step 12, image 2 of 2
    • Using the plastic opening tool, open the device's outer shell.
  13. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: step 13, image 1 of 2 Sony Cyber-Shot DSC-TX30 Movie Button Replacement: step 13, image 2 of 2
    • Remove the front casing of the device.
  14. Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Back Casing: step 14, image 1 of 3 Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Back Casing: step 14, image 2 of 3 Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Back Casing: step 14, image 3 of 3
    • Using the plastic opening tool, remove the back casing of the device.
  15. Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Movie Button: step 15, image 1 of 2 Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Movie Button: step 15, image 2 of 2
    Tool used on this step:
    Buy
    • Using the tweezers, remove the movie button from the back casing of the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 296
