Sony Cyber-Shot DSC-W120 Lens Assembly Replacement
  1. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement, Lens Assembly: step 1, image 1 of 1
    • Unscrew the screws on the right side of the camera.
  2. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: step 2, image 1 of 2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: step 2, image 2 of 2
    • Using a plastic opening tool, gently lift the side of the silver piece on the right side of the camera until it can be removed.
  3. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: step 3, image 1 of 3 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: step 3, image 2 of 3 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: step 3, image 3 of 3
    • Use a plastic opening tool to separate the front case of the camera, and gently remove it.
  4. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to remove the silver piece on the left side of the camera.
  5. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: step 5, image 1 of 1
    • Remove the three screws from the bottom of the camera.
  6. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: step 6, image 1 of 2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: step 6, image 2 of 2
    • Carefully remove the back case with a plastic opening tool.
  7. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: step 7, image 1 of 1
    • Unscrew the screw just above the mode dial.
  8. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • Lift the display from the rest of the camera and gently separate the connecting tape using tweezers.
  9. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: step 9, image 1 of 2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: step 9, image 2 of 2
    • Separate the tape connecting the lens to the rest of the camera using tweezers.
    • Remove the lens.
  10. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: step 10, image 1 of 2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: step 10, image 2 of 2
    • Insert wisdom here.
  11. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: step 11, image 1 of 1
Dana Sanchez
51 Reputation
3 Guides authored
USF Tampa, Team 1-5, Leahy Fall 2014 Member of USF Tampa, Team 1-5, Leahy Fall 2014
USFT-LEAHY-F14S1G5
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 45
All Time: 1,720
