Sony Cyber-Shot DSC-W170 LCD Replacement
  1. Sony Cyber-Shot DSC-W170 LCD Replacement, LCD Panel Assembly: step 1, image 1 of 3 Sony Cyber-Shot DSC-W170 LCD Replacement, LCD Panel Assembly: step 1, image 2 of 3 Sony Cyber-Shot DSC-W170 LCD Replacement, LCD Panel Assembly: step 1, image 3 of 3
    • Be sure to remove the battery before performing this task.
    • Remove the five 4 mm screws with a Phillips #000 screwdriver.
  2. Sony Cyber-Shot DSC-W170 LCD Replacement: step 2, image 1 of 1
    • Use an opening pick to pry the LCD panel open.
  3. Sony Cyber-Shot DSC-W170 LCD Replacement: step 3, image 1 of 1
    • Gently remove the LCD panel from the rest of the camera.
  4. Sony Cyber-Shot DSC-W170 LCD Replacement, Front Panel: step 4, image 1 of 3 Sony Cyber-Shot DSC-W170 LCD Replacement, Front Panel: step 4, image 2 of 3 Sony Cyber-Shot DSC-W170 LCD Replacement, Front Panel: step 4, image 3 of 3
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  5. Sony Cyber-Shot DSC-W170 LCD Replacement: step 5, image 1 of 1
    • Gently open the front panel and remove it from the rest of the camera.
  6. Sony Cyber-Shot DSC-W170 LCD Replacement, LCD: step 6, image 1 of 2 Sony Cyber-Shot DSC-W170 LCD Replacement, LCD: step 6, image 2 of 2
    • Remove the first side panel to the left of the LCD.
    • Remove the 4 mm screw from the other side panel to the right of the LCD with a Phillips #000 screwdriver.
  7. Sony Cyber-Shot DSC-W170 LCD Replacement: step 7, image 1 of 3 Sony Cyber-Shot DSC-W170 LCD Replacement: step 7, image 2 of 3 Sony Cyber-Shot DSC-W170 LCD Replacement: step 7, image 3 of 3
    • Gently, lift the LCD and carefully open the camera to disconnect the LCD ribbon cable from the motherboard.
  8. Sony Cyber-Shot DSC-W170 LCD Replacement: step 8, image 1 of 2 Sony Cyber-Shot DSC-W170 LCD Replacement: step 8, image 2 of 2
    • Gently push the connector through the hole to separate the LCD from the metal casing.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 96
