Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement
  1. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: step 1, image 1 of 3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: step 1, image 2 of 3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: step 1, image 3 of 3
    • Remove the battery before beginning.
    • Remove the three screws from the side of the lens using a JIS #000 screwdriver.
    • Remove the longer single screw from the bottom of the lens using a JIS #000 screwdriver.
  2. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: step 2, image 1 of 2 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: step 2, image 2 of 2
    • Remove the housing over the lens circuit board.
    • When removing the housing from over the circuit board, be cautious of static when touching the circuit board as to not fry any necessary components.
  3. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: step 3, image 1 of 1
    • Unplug the micro-USB type B port from the main circuit board in the lens.
    • When handling the flex cable, be careful as to not destroy this delicate part and cause damage to other components.
  4. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: step 4, image 2 of 2
    • Set the camera aside.
    • Remove the two JIS #000 screws connecting the micro-USB type B port to the housing frame.
  5. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: step 5, image 1 of 3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: step 5, image 2 of 3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: step 5, image 3 of 3
    • Remove the damaged micro-USB type B port by lightly pulling near the cable connector.
    • Remove the micro-USB port from the case and replace it with a new micro-USB type B port.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 913
