Sony Cyber-shot DSC-H20 Lens Assembly Replacement
  1. Sony Cyber-shot DSC-H20 Lens Assembly Replacement, Lens Assembly: step 1, image 1 of 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement, Lens Assembly: step 1, image 2 of 2
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 2, image 1 of 1
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 3, image 1 of 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 3, image 2 of 2
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 4, image 1 of 3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 4, image 2 of 3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 4, image 3 of 3
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 5, image 1 of 1
    • Place the camera upside down with the battery port positioned upward and the battery port open.
  6. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 6, image 1 of 3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 6, image 2 of 3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 6, image 3 of 3
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 7, image 1 of 1
    • Remove the power shutter unit
  8. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 8, image 1 of 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 8, image 2 of 2
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
  9. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 9, image 1 of 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 9, image 2 of 2
    • Lift up the gray plastic facing in order to uncover the motherboard and the ribbon cable ports.
  10. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 10, image 1 of 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 10, image 2 of 2
    • Carefully flip up the three black clasps holding the lens cables to the motherboard.
    • Slide the cables from the ports.
  11. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: step 11, image 1 of 1
    • Lift the lens and attached ribbon cables from the camera in order to switch this lens with a new one.
Rachel Payne
386 Reputation
2 Guides authored
USF Tampa, Team 1-1, Leahy Winter 2015 Member of USF Tampa, Team 1-1, Leahy Winter 2015
USFT-LEAHY-W15S1G1
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 32
All Time: 2,746
