Sony Cyber-shot DSC-H200 LCD Screen Replacement
  1. Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: step 1, image 1 of 3 Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: step 1, image 2 of 3 Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: step 1, image 3 of 3
    • Using a screwdriver, remove the five 6mm screws located on the back panel.
    • Using a screwdriver, remove the two 3mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 LCD Screen Replacement: step 2, image 1 of 1
    • Using a screwdriver, remove one 6mm screw on the front panel.
    • Using a screwdriver, remove two 3mm screws on the front panel.
  3. Sony Cyber-shot DSC-H200 LCD Screen Replacement: step 3, image 1 of 1
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 LCD Screen Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-H200 LCD Screen Replacement: step 4, image 2 of 2
    • Remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 LCD Screen Replacement: step 5, image 1 of 1
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard. (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable.)
  6. Sony Cyber-shot DSC-H200 LCD Screen Replacement: step 6, image 1 of 1
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 LCD Screen Replacement: step 7, image 1 of 2 Sony Cyber-shot DSC-H200 LCD Screen Replacement: step 7, image 2 of 2
    • Lift the holding plate away from the motherboard and set aside.
  8. Sony Cyber-shot DSC-H200 LCD Screen Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers, open the LCD ribbon port by lifting the black hinge. (The LCD ribbon cable will detach.)
  9. Sony Cyber-shot DSC-H200 LCD Screen Replacement: step 9, image 1 of 3 Sony Cyber-shot DSC-H200 LCD Screen Replacement: step 9, image 2 of 3 Sony Cyber-shot DSC-H200 LCD Screen Replacement: step 9, image 3 of 3
    • Using tweezers, remove the LCD with the ribbon cable and set aside.
One Comment
Where can you purchase a new replacement monitor?
Butch Sullivan - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 16
All Time: 2,519
