Sony Cyber-shot DSC-H200 SD Door Replacement
  1. Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: step 1, image 1 of 2 Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: step 1, image 2 of 2
    • Using a screwdriver, remove four 6mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 SD Door Replacement: step 2, image 1 of 1
    • Using a screwdriver, remove the two 6mm screws on the bottom.
    • Using a screwdriver, remove the four 3mm screws on the bottom.
  3. Sony Cyber-shot DSC-H200 SD Door Replacement: step 3, image 1 of 1
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 SD Door Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-H200 SD Door Replacement: step 4, image 2 of 2
    • Using the blue plastic opening tools, remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 SD Door Replacement: step 5, image 1 of 2 Sony Cyber-shot DSC-H200 SD Door Replacement: step 5, image 2 of 2
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable).
    • Using the blue plastic opening tool remove the LCD Screen from the motherboard.
  6. Sony Cyber-shot DSC-H200 SD Door Replacement: step 6, image 1 of 1
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 SD Door Replacement: step 7, image 1 of 1
    • Lift the holding plate away from the motherboard and set aside (the pin attaching the door to the body is now accessible).
  8. Sony Cyber-shot DSC-H200 SD Door Replacement: step 8, image 1 of 2 Sony Cyber-shot DSC-H200 SD Door Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers remove the pin that attaches the door to the body.
  9. Sony Cyber-shot DSC-H200 SD Door Replacement: step 9, image 1 of 1
    • Remove the door.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 1,589
