Sony Cyber-shot DSC-H200 Tripod Port Replacement
  1. Sony Cyber-shot DSC-H200 Tripod Port Replacement, LCD Screen: step 1, image 1 of 3 Sony Cyber-shot DSC-H200 Tripod Port Replacement, LCD Screen: step 1, image 2 of 3 Sony Cyber-shot DSC-H200 Tripod Port Replacement, LCD Screen: step 1, image 3 of 3
    • Using a screwdriver, remove the five 6mm screws located on the back panel.
    • Using a screwdriver, remove the two 3mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 2, image 1 of 1
    • Using a screwdriver, remove one 6mm screw on the front panel.
    • Using a screwdriver, remove two 3mm screws on the front panel.
  3. Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 3, image 1 of 1
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 4, image 2 of 2
    • Remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 5, image 1 of 1
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard. (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable.)
  6. Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 6, image 1 of 1
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 7, image 1 of 2 Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 7, image 2 of 2
    • Lift the holding plate away from the motherboard and set aside.
  8. Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers, open the LCD ribbon port by lifting the black hinge. (The LCD ribbon cable will detach.)
  9. Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 9, image 1 of 3 Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 9, image 2 of 3 Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 9, image 3 of 3
    • Using tweezers, remove the LCD with the ribbon cable and set aside.
  10. Sony Cyber-shot DSC-H200 Tripod Port Replacement, Motherboard: step 10, image 1 of 1
    Buy
    • Disconnect the four amber-colored ribbon cables from the motherboard using tweezers.
  11. Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 11, image 1 of 1
    • Disconnect all wires from the motherboard by using a soldering iron.
    • Users unfamiliar with a soldering iron should be extremely careful as the device can get very hot.
  12. Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 12, image 1 of 1
    • Gently lift the motherboard away from the camera body.
  13. Sony Cyber-shot DSC-H200 Tripod Port Replacement, Tripod Port: step 13, image 1 of 1
    • Using a screwdriver, remove the four 4mm screws from the motherboard.
    • Then remove the single 4mm screw connecting the motherboard to the main body of the camera.
  14. Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 14, image 1 of 1
    • Lift the motherboard away from the camera body (the tripod port is exposed)
  15. Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 15, image 1 of 3 Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 15, image 2 of 3 Sony Cyber-shot DSC-H200 Tripod Port Replacement: step 15, image 3 of 3
    Buy
    • Using tweezers, lift the tripod port up and away from the camera body
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 1,239
