Sony Cyber-shot DSC-H55 LCD Screen Replacement
  1. Sony Cyber-shot DSC-H55 LCD Screen Replacement, Removing Screws: step 1, image 1 of 2 Sony Cyber-shot DSC-H55 LCD Screen Replacement, Removing Screws: step 1, image 2 of 2
    • Use the Phillips #00 screwdriver to remove the two screws located on the right side of the camera.
  2. Sony Cyber-shot DSC-H55 LCD Screen Replacement, Removing Bottom Piece: step 2, image 1 of 3 Sony Cyber-shot DSC-H55 LCD Screen Replacement, Removing Bottom Piece: step 2, image 2 of 3 Sony Cyber-shot DSC-H55 LCD Screen Replacement, Removing Bottom Piece: step 2, image 3 of 3
    • Use the Phillips #00 screwdriver to remove the three screws on the bottom of the camera.
    • Use the plastic opening tool to lift the cover containing the patent information off.
  3. Sony Cyber-shot DSC-H55 LCD Screen Replacement, Removing Left Side Piece: step 3, image 1 of 2 Sony Cyber-shot DSC-H55 LCD Screen Replacement, Removing Left Side Piece: step 3, image 2 of 2
    • Place the plastic opening tool in the crack between the metal circle and the black piece on the left.
    • Slide the black cover and lift to remove.
  4. Sony Cyber-shot DSC-H55 LCD Screen Replacement, Removing Newly Exposed Screws: step 4, image 1 of 3 Sony Cyber-shot DSC-H55 LCD Screen Replacement, Removing Newly Exposed Screws: step 4, image 2 of 3 Sony Cyber-shot DSC-H55 LCD Screen Replacement, Removing Newly Exposed Screws: step 4, image 3 of 3
    • The first picture shows how the left side of the camera looks once we remove the side piece.
    • Use the Phillips #00 screwdriver to remove the two screws on this left side.
    • Flip your camera to the right side where we removed the first two screws.
    • Use the plastic opening tool into the crack and lift in order to loosen that side of the shell. Loosening one side makes removing the entire shell easier.
  5. Sony Cyber-shot DSC-H55 LCD Screen Replacement, Removing Back Shell: step 5, image 1 of 2 Sony Cyber-shot DSC-H55 LCD Screen Replacement, Removing Back Shell: step 5, image 2 of 2
    • Once the side is loose, apply a small amount of force to remove the shell.
    • Remove one side and then the other to avoid breaking any piece of the camera.
    • Keep the battery compartment open to make this step easier.
  6. Sony Cyber-shot DSC-H55 LCD Screen Replacement, Removing the Motherboard: step 6, image 1 of 3 Sony Cyber-shot DSC-H55 LCD Screen Replacement, Removing the Motherboard: step 6, image 2 of 3 Sony Cyber-shot DSC-H55 LCD Screen Replacement, Removing the Motherboard: step 6, image 3 of 3
    • Removing the outer shell will expose the motherboard (the green chip).
    • Carefully grab the motherboard and flip it over.
    • Locate the ribbon wire protruding from the motherboard. Grip the wire as close to the white square as possible and slightly pull it to disconnect it from the wire.
  7. Sony Cyber-shot DSC-H55 LCD Screen Replacement, Detaching Metal around LCD Screen: step 7, image 1 of 3 Sony Cyber-shot DSC-H55 LCD Screen Replacement, Detaching Metal around LCD Screen: step 7, image 2 of 3 Sony Cyber-shot DSC-H55 LCD Screen Replacement, Detaching Metal around LCD Screen: step 7, image 3 of 3
    • Remove the LCD Screen to separate the metal frame connecting the screen to the camera.
    • Gently pull the metal frame away, keeping in mind that the right end of the screen is attached by a ribbon wire.
    • Slowly remove the metal frame until it fully pops off.
  8. Sony Cyber-shot DSC-H55 LCD Screen Replacement, Detaching Ribbon Wires: step 8, image 1 of 3 Sony Cyber-shot DSC-H55 LCD Screen Replacement, Detaching Ribbon Wires: step 8, image 2 of 3 Sony Cyber-shot DSC-H55 LCD Screen Replacement, Detaching Ribbon Wires: step 8, image 3 of 3
    • Flip the metal screen to be facing down. There will be a small black clip on the white connector that will allows the ribbon wire to be removed.
    • Carefully lift the black clip and slide the ribbon out in order to remove the LCD screen.
Jazmin Young
608 Reputation
5 Guides authored
USF Tampa, Team 6-2, Brown Winter 2015 Member of USF Tampa, Team 6-2, Brown Winter 2015
USFT-BROWN-W15S6G2
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 26
All Time: 1,173
