Sony Cyber-shot DSC-HX1 Battery Replacement
  1. Sony Cyber-shot DSC-HX1 Battery Replacement, Battery: step 1, image 1 of 1
    • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
    • Place the camera with the bottom facing you and the lens facing up.
  2. Sony Cyber-shot DSC-HX1 Battery Replacement: step 2, image 1 of 1
    • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
  3. Sony Cyber-shot DSC-HX1 Battery Replacement: step 3, image 1 of 2 Sony Cyber-shot DSC-HX1 Battery Replacement: step 3, image 2 of 2
    • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
    • The battery is not shown here. However, normally the battery would be in the displayed compartment.
To reassemble your device, insert the new battery in the compartment, making sure that your battery has the correct orientation, then follow these instructions in reverse order.
Brianna Greenlaw
1,217 Reputation
5 Guides authored
Cal Poly, Team 17-3, Forte Spring 2015 Member of Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 34
All Time: 1,351
