Sony Cyber-shot DSC-HX1 LCD Screen Replacement
  1. Sony Cyber-shot DSC-HX1 LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Extend the LCD screen away from the camera to access the screws on the back of its housing.
  2. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: step 2, image 1 of 1
    • Unscrew the three #00 2.0 mm Phillips screws on the back of the casing.
  3. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: step 3, image 1 of 1
    • Place the camera with the lens down.
    • Tilt the screen upwards to see the screw on the bottom of the housing.
    • Unscrew this #00 4.0 mm Phillips screw.
  4. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: step 4, image 1 of 1
    • Pry the casing apart using your plastic opening tool. Begin by prying at the hole where you removed the screw and continue along the seam.
  5. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: step 5, image 1 of 2 Sony Cyber-shot DSC-HX1 LCD Screen Replacement: step 5, image 2 of 2
    • Lift the transparent section of the plastic housing off.
    • Lift the rubber screen bumper off of the screen.
  6. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: step 6, image 1 of 1
    • Pull up on the screen to reveal the data attachment cable.
    • Carefully pull the LCD screen away from enclosure to remove the cable and screen completely.
5 other people completed this guide.
Brianna Greenlaw
1,181 Reputation
5 Guides authored
Cal Poly, Team 17-3, Forte Spring 2015 Member of Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
4 Members
10 Guides authored
5 Comments
What is the lcd screen part number? And where can i find it online? I need to replace my dads cracked screen.
sportyvangchick - Reply
lao90227ay
s300gc05lb9e21xmo usp5280371
lajos rohony - Reply
Display my order
prince Choudhary - Reply
Screen LCDOnline booking
qual tela de lcd posso usar?
não achei
Thayane Laurencio - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 45
All Time: 3,251
