Sony Cyber-shot DSC-HX100V Viewfinder Replacement
  1. Sony Cyber-shot DSC-HX100V Viewfinder Replacement, Viewfinder: step 1, image 1 of 1
    • Make sure camera is turned off.
    • Press the ON/Off button to turn off the camera.
    • WARNING: Data may be lost if the camera remains on.
  2. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: step 2, image 1 of 3 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: step 2, image 2 of 3 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: step 2, image 3 of 3
    • Use the Phillips screwdriver size #00 to remove the 1.59mm #00 screws.
    • Remove 2 screws from the side of the camera.
    • Remove 4 screws on the bottom of the camera.
    • Remove 1 screw next to the eyepiece.
  3. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: step 3, image 1 of 1
    • Flip the screen back to reveal 2 hidden screws.
    • Remove the two 1.59mm #00 screws on the left with the Phillips #00 screwdriver.
  4. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: step 4, image 1 of 1
    • Pull the back panel of the camera upward.
    • Use a spudger to help pry open the back panel.
  5. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: step 5, image 1 of 1
    • Open the back panel to view the inside of the camera.
    • If the orange ribbon cable disconnects from its designated port, do not panic. The cable is easy to reinsert.
  6. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: step 6, image 1 of 3 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: step 6, image 2 of 3 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: step 6, image 3 of 3
    • Carefully pull out the the eyepiece.
    • Detach the orange ribbon cable that connects it to the green panel by carefully pulling outwards.
DaQuawn
254 Reputation
2 Guides authored
One Comment
Thank you very much for the importent articles made for us. If I can please put , how to replace the flasher as well.
Satsara Gunaratne - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 939
