Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement
  1. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Battery: step 1, image 1 of 1
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: step 2, image 1 of 1
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: step 3, image 1 of 1
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: step 4, image 2 of 2
    • Remove the battery.
  5. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: step 5, image 1 of 3 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: step 5, image 2 of 3 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: step 5, image 3 of 3
    • Make sure to remove the battery before disassembly to prevent electrocution.
    • Remove the 3 (4 cm) Phillips head screws located on the back of the camera.
    • Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
    • Turn the camera upside down to remove the remaining the 3 (4 cm) Phillips head screws holding the plastic camera housing together.
  6. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: step 6, image 1 of 2 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: step 6, image 2 of 2
    • Using a plastic opening tool, separate the plastic camera housing.
  7. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: step 7, image 1 of 1
    • Disconnect the ribbon wire attaching the screen to the camera.
  8. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: step 8, image 1 of 3 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: step 8, image 2 of 3 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: step 8, image 3 of 3
    • Carefully remove the 7 ribbon wires connected to the mother board.
    • Remove the 2 (5 cm) Phillips head screws on the speaker mounting bracket.
    • Remove the 3 (4 cm) Phillips head screws that secure the motherboard to the camera.
    • Lift up on the speaker mounting bracket to remove it.
  9. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: step 9, image 1 of 2 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: step 9, image 2 of 2
    • Carefully disconnect the ribbon wire connecting the HDMI port to the Motherboard.
    • Once the Motherboard is removed the replacement can be installed.
  10. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, HDMI/USB port: step 10, image 1 of 1
    • Remove the 3 (4 cm) Phillips head screws securing a mounting bracket over the HDMI/USB Port.
  11. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: step 11, image 1 of 1
    • Lift up on the mounting bracket to remove the HDMI/USB Port from the camera.
  12. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: step 12, image 1 of 1
    • Once the HDMI/USB Port is removed the replacement can be installed.
2 other people completed this guide.
Elizabeth Surface
1,465 Reputation
9 Guides authored
USF Tampa, Team 4-6, Meier Fall 2015 Member of USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 13
All Time: 1,562
