Sony Cyber-shot DSC-HX80 LCD Screen Replacement
  1. Sony Cyber-shot DSC-HX80 LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Before disassembling any part of the camera, turn off the power by pressing down on the ON/OFF button. The ON/OFF button is located on top of the camera.
  2. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: step 2, image 1 of 1
    • Open the compartment located at the bottom of the camera. Slide the LOCK/OPEN switch to the OPEN side. Locate the small blue tab on the side. Pull it in direction away from battery. Remove the battery and set it aside.
  3. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: step 3, image 1 of 2 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: step 3, image 2 of 2
    • Flip LCD screen upwards.
    • Use the PH000 Phillips head screwdriver to remove the two 0.3 mm Phillips black screws located on the sides of the LCD screen. Place screws on magnetic mat or plastic bag.
  4. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: step 4, image 2 of 2
    • Use the PH000 Phillips head screwdriver to remove the two additional 0.3 mm black Phillips screws located on the top edge of the LCD screen. Place screws on magnetic mat or plastic bag.
  5. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: step 5, image 1 of 3 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: step 5, image 2 of 3 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: step 5, image 3 of 3
    • Use a nylon spudger to gently remove the damaged LCD screen off the camera.
    • Replace LCD screen with new one.
4 other people completed this guide.
Gordon Jones
1,057 Reputation
5 Guides authored
6 Comments
You should note that there is a small rectangular magnet (perhaps 8mm long and 2mm across) that has to be placed at the top of the LCD directly under the flash switch. Otherwise the LCD image will be upside down.
Dale Bjerning - Reply
Hello could you show a picture of where exactly under the flash has to be the magnetite tangle. Thanks.
Wolfina -
Anyone know where I can find the cable from the screen to the camera?
Thorusofer Dragon Knight - Reply
where can i find the screen other then threw sony
ninjadawn25 - Reply
Im looking for lcd screen for sony dsc hx80 on back TX08D155HMOAAA. A9N9I523946
Kaz Balcerzak - Reply
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 68
All Time: 3,377
