Sony Cyber-shot DSC-HX90V Button Board Replacement
  1. Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: step 1, image 1 of 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: step 1, image 2 of 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: step 1, image 3 of 3
    • Remove the marked screw with a Phillips #000 screwdriver.
    • Remove the marked black M1.4 X 3.5 Phillips head screws
    • Use the spudger to gently remove the lower panel.
  2. Sony Cyber-shot DSC-HX90V Button Board  Replacement: step 2, image 1 of 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: step 2, image 2 of 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: step 2, image 3 of 3
    • After removing the marked black M1.4 X 3.5 Phillips head screws with the Phillips #000 screwdriver on the side panel, using the spudger where the red arrow marks, insert and gently remove the side panel from the device.
    • From either corner of the button board gently use hands to remove the button board.
  3. Sony Cyber-shot DSC-HX90V Button Board  Replacement: step 3, image 1 of 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: step 3, image 2 of 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • After the outer black panel case of button is removed, gently disconnect the control board data cable to the motherboard utilizing the tweezers gently where the red arrow marks.
    • Ribbon wires can easily be damaged.
Marin Rusinov
853 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 34
All Time: 2,076
