Sony Cyber-shot DSC-HX90V Motherboard Replacement
  1. Sony Cyber-shot DSC-HX90V Motherboard Replacement, Button board: step 1, image 1 of 1
    • Place the device so bottom of the camera is facing up .
    • Remove the five black M1.4 X 3.5 Phillips head screws with a Phillips #000 screwdriver.
  2. Sony Cyber-shot DSC-HX90V Motherboard Replacement: step 2, image 1 of 1
    • Remove the marked black M1.4 X 3.5 Phillips head screws on the side of the camera with a Phillips #000 screwdriver.
  3. Sony Cyber-shot DSC-HX90V Motherboard Replacement: step 3, image 1 of 1
    • Remove the marked screw with a Phillips #000 screwdriver.
  4. Sony Cyber-shot DSC-HX90V Motherboard Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-HX90V Motherboard Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to remove the button board.
  5. Sony Cyber-shot DSC-HX90V Motherboard Replacement: step 5, image 1 of 2 Sony Cyber-shot DSC-HX90V Motherboard Replacement: step 5, image 2 of 2
    • Disconnect the control board data cable with care. Permanent damage may occur to the control board if tools are used to disconnect the data cable. Use your fingers only.
    • Disconnect the control board data cable by wiggling carefully with your fingertips. Set the control board to the side once it is disconnected.
  6. Sony Cyber-shot DSC-HX90V Motherboard Replacement, Side cover: step 6, image 1 of 1
    • Use the plastic opening tool with a prying motion to remove the side cover of the camera.
    • The cover should come off easily but you might hear light snapping or popping.
  7. Sony Cyber-shot DSC-HX90V Motherboard Replacement, LCD: step 7, image 1 of 1
    • Orient the device so the lens is facing down.
    • Remove the two black M1.4 X 3.5 Phillips head screws using Phillips #000 screwdriver.
  8. Sony Cyber-shot DSC-HX90V Motherboard Replacement: step 8, image 1 of 1
    • Remove the black M1.4 X 3.5 Phillips head screw.
  9. Sony Cyber-shot DSC-HX90V Motherboard Replacement: step 9, image 1 of 2 Sony Cyber-shot DSC-HX90V Motherboard Replacement: step 9, image 2 of 2
    • LCD screen is very fragile. Handle with care. Do not use tools to remove the screen.
    • Remove the ribbon cable connecting LCD display to camera sensor and battery housing.
  10. Sony Cyber-shot DSC-HX90V Motherboard Replacement, Motherboard: step 10, image 1 of 1
    • Make sure all ribbon cables are unplugged and remove the motherboard.
    • Ribbon wires can be easily damaged.
Marin Rusinov
853 Reputation
5 Guides authored
2 Comments
super Anleitung, trotz aller Vorsicht ist ein Flachbandkabel kaputt gegangen, und zwar das 2 adrige zu Sucher. Wie kann man Flachbandkabel reparieren oder ersetzen?
LG
Michael
Michael Bühnen - Reply
Hello!
Nice help to open the camera for fixing viewfinder problems: when not switching on, even when FINDER/MONITOR mode on FINDER, there might be a bad contact in the visor connector. It is a snap lock micro connector, open the lock, then carefully remove clean and replace ribbon cable:this may clear the trouble.
But attention: At least on HX9O without V ext. there are some more screws ;-) and niceties
- one in step 3, under the MULTI connector cap
- 3 on different places to remove LCD screen
Also, there is also an antenna , connected to the LCD assembly and lightly glued on the side
Frantz Bernhard - Reply
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 52
All Time: 3,158
