Sony Cyber-shot DSC-HX9V Battery Replacement
  1. Sony Cyber-shot DSC-HX9V Battery Replacement, Battery: step 1, image 1 of 1
    • Ensure the camera is powered off prior to removal of the battery. The LCD screen will have no information displayed if the camera is properly turned off.
    • Place the camera upside down with the top sitting on a flat surface.
    • Using your fingers, slide the door lock to the unlock position.
  2. Sony Cyber-shot DSC-HX9V Battery Replacement: step 2, image 1 of 1
    • Open the battery compartment door.
    • Remove the battery from the compartment by turning the camera upside down and allow it to slide out. Be sure to catch the battery as it slides out.
    • If you are replacing internal camera parts, stop here. If you are replacing the old battery, continue with step 2.
    • Sony recommends the use of an approved battery for maximum performance. The recommended battery model number is NP-FG1.
    • Insert the new battery into the compartment matching the positive battery lead to the positive terminal and the negative battery lead to the negative terminal on the camera.
    • Close and lock the battery door and power the camera up. Ensure to check the battery charge levels and that all functions of the camera work properly.
Kris
587 Reputation
4 Guides authored
UW Tacoma, Team 1-2, Rose Fall 2016 Member of UW Tacoma, Team 1-2, Rose Fall 2016
UWT-ROSE-F16S1G2
4 Members
12 Guides authored
One Comment
Hello @jetblast Thanks for this guide. Flash of my HX9V is not working properly. It actaully popus up but doesn’t throw the white light. I got it checked in the Sony Service center and this is what they suggested me to change: http://prntscr.com/qidtm4 Can anyone identity these two parts and from where I can get them? Also, any repaid guide available on how to change the flash?
Thanks in advance!
Raj - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 54
All Time: 2,539
