Sony Cyber-shot DSC-T1 Motherboard Replacement
  1. Sony Cyber-shot DSC-T1 Motherboard Replacement, Battery: step 1, image 1 of 2 Sony Cyber-shot DSC-T1 Motherboard Replacement, Battery: step 1, image 2 of 2
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Sony Cyber-shot DSC-T1 Motherboard Replacement: step 2, image 1 of 1
    • Remove the battery from the door that you opened in the previous step.
  3. Sony Cyber-shot DSC-T1 Motherboard Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: step 3, image 1 of 3 Sony Cyber-shot DSC-T1 Motherboard Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: step 3, image 2 of 3 Sony Cyber-shot DSC-T1 Motherboard Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: step 3, image 3 of 3
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Sony Cyber-shot DSC-T1 Motherboard Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-T1 Motherboard Replacement: step 4, image 2 of 2
    • Use hands to gently pry the front casing away from the camera.
  5. Sony Cyber-shot DSC-T1 Motherboard Replacement, CCD Sensor Module: step 5, image 1 of 2 Sony Cyber-shot DSC-T1 Motherboard Replacement, CCD Sensor Module: step 5, image 2 of 2
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  6. Sony Cyber-shot DSC-T1 Motherboard Replacement: step 6, image 1 of 1
    • Grasp the CCD Sensor Module and remove it.
  7. Sony Cyber-shot DSC-T1 Motherboard Replacement, Flash Module: step 7, image 1 of 3 Sony Cyber-shot DSC-T1 Motherboard Replacement, Flash Module: step 7, image 2 of 3 Sony Cyber-shot DSC-T1 Motherboard Replacement, Flash Module: step 7, image 3 of 3
    • This camera houses a very strong capacitor (the black cylinder). Avoid touching anything around the two wires coming out of the top. Doing so will risk serious electric shock.
    • Carefully disengage the internal components from the casing by lifting at the bottom end and giving a gentle tug.
    • The components are still connected to the casing via cables, but they are much more maneuverable.
    • The flash module is shown on the right hand side.
  8. Sony Cyber-shot DSC-T1 Motherboard Replacement: step 8, image 1 of 2 Sony Cyber-shot DSC-T1 Motherboard Replacement: step 8, image 2 of 2
    • Use the tip of a spudger to flip up the tab on the ZIF connecter securing the motherboard ribbon cable.
    • Grasp the flash module by the bottom and remove it.
  9. Sony Cyber-shot DSC-T1 Motherboard Replacement, Motherboard Assembly: step 9, image 1 of 2 Sony Cyber-shot DSC-T1 Motherboard Replacement, Motherboard Assembly: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to slide the white piece on the back of the back cover to the right.
    • This will dislodge the white piece, allowing you to remove it from the back cover.
  10. Sony Cyber-shot DSC-T1 Motherboard Replacement: step 10, image 1 of 1
    • Remove the ribbon cables from these two ZIF connectors.
  11. Sony Cyber-shot DSC-T1 Motherboard Replacement: step 11, image 1 of 2 Sony Cyber-shot DSC-T1 Motherboard Replacement: step 11, image 2 of 2
    • Lift the motherboard assembly up and rotate it so you can easily see where the internals connect to the back cover.
    • Remove the ZIF connectors from the clamp on the left end of the top piece.
    • The motherboard assembly is now separated from the back cover.
  12. Sony Cyber-shot DSC-T1 Motherboard Replacement, Motherboard: step 12, image 1 of 1
    • Locate the screw inside the small white piece on the motherboard assembly.
    • Remove this 2.9mm screw using a PH00 screwdriver.
  13. Sony Cyber-shot DSC-T1 Motherboard Replacement: step 13, image 1 of 1
    Buy
    • Use tweezers to remove the small white piece from the motherboard assembly.
  14. Sony Cyber-shot DSC-T1 Motherboard Replacement: step 14, image 1 of 1
    • Turn the motherboard assembly over.
    • Use a spudger to open the ZIF connector on the motherboard.
    • Remove the ribbon cables from the opened clip.
  15. Sony Cyber-shot DSC-T1 Motherboard Replacement: step 15, image 1 of 2 Sony Cyber-shot DSC-T1 Motherboard Replacement: step 15, image 2 of 2
    • Pry the motherboard slightly apart form the motherboard assembly.
    • Be careful while separating the board so that you do not damage the ribbon cables or other components.
    • Disconnect the ribbon cable connecting the battery pack to the motherboard.
  16. Sony Cyber-shot DSC-T1 Motherboard Replacement: step 16, image 1 of 3 Sony Cyber-shot DSC-T1 Motherboard Replacement: step 16, image 2 of 3 Sony Cyber-shot DSC-T1 Motherboard Replacement: step 16, image 3 of 3
    • Pull the motherboard up from the battery pack and flip the motherboard assembly over.
    • Use a PH00 screwdriver to remove the 2.9mm screw connecting the speaker to the battery pack.
iDeleted
2,101 Reputation
39 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 22
All Time: 2,476
