Sony Cyber-shot DSC-T9 Back Cover Replacement
  1. Sony Cyber-shot DSC-T9 Back Cover Replacement, Battery: step 1, image 1 of 1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 Back Cover Replacement: step 2, image 1 of 1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 Back Cover Replacement, Front Cover: step 3, image 1 of 3 Sony Cyber-shot DSC-T9 Back Cover Replacement, Front Cover: step 3, image 2 of 3 Sony Cyber-shot DSC-T9 Back Cover Replacement, Front Cover: step 3, image 3 of 3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 Back Cover Replacement: step 4, image 1 of 1
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 Back Cover Replacement: step 5, image 1 of 1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 Back Cover Replacement: step 6, image 1 of 1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 Back Cover Replacement, Back Cover: step 7, image 1 of 1
    • This is the camera without the front cover.
  8. Sony Cyber-shot DSC-T9 Back Cover Replacement: step 8, image 1 of 1
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  9. Sony Cyber-shot DSC-T9 Back Cover Replacement: step 9, image 1 of 3 Sony Cyber-shot DSC-T9 Back Cover Replacement: step 9, image 2 of 3 Sony Cyber-shot DSC-T9 Back Cover Replacement: step 9, image 3 of 3
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  10. Sony Cyber-shot DSC-T9 Back Cover Replacement: step 10, image 1 of 3 Sony Cyber-shot DSC-T9 Back Cover Replacement: step 10, image 2 of 3 Sony Cyber-shot DSC-T9 Back Cover Replacement: step 10, image 3 of 3
    • Pull apart the inner hardware from the back case by prying on the left side.
  11. Sony Cyber-shot DSC-T9 Back Cover Replacement: step 11, image 1 of 1
    • Remove the back cover.
  12. Sony Cyber-shot DSC-T9 Back Cover Replacement: step 12, image 1 of 1
    • The back cover is now removed from the internal hardware.
Stephannie Allen
255 Reputation
10 Guides authored
Clemson, Team 13-1, Benson Spring 2013 Member of Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Members
20 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 11
All Time: 569
