Sony Cyber-shot DSC-T9 Motherboard Replacement
Stephannie Allen
Stephannie Allen and 2 other contributors
Last updated on December 10, 2020
No estimate
Difficult
Introduction
Go to step 1
This guide will allow the user to access the motherboard for installation, replacement, or removal.
Tools
Show more…
  1. Sony Cyber-shot DSC-T9 Motherboard Replacement, Battery: step 1, image 1 of 1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 2, image 1 of 1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 Motherboard Replacement, Front Cover: step 3, image 1 of 3 Sony Cyber-shot DSC-T9 Motherboard Replacement, Front Cover: step 3, image 2 of 3 Sony Cyber-shot DSC-T9 Motherboard Replacement, Front Cover: step 3, image 3 of 3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 4, image 1 of 1
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 5, image 1 of 1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 6, image 1 of 1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 Motherboard Replacement, Back Cover: step 7, image 1 of 1
    • This is the camera without the front cover.
  8. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 8, image 1 of 1
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  9. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 9, image 1 of 3 Sony Cyber-shot DSC-T9 Motherboard Replacement: step 9, image 2 of 3 Sony Cyber-shot DSC-T9 Motherboard Replacement: step 9, image 3 of 3
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  10. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 10, image 1 of 3 Sony Cyber-shot DSC-T9 Motherboard Replacement: step 10, image 2 of 3 Sony Cyber-shot DSC-T9 Motherboard Replacement: step 10, image 3 of 3
    • Pull apart the inner hardware from the back case by prying on the left side.
  11. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 11, image 1 of 1
    • Remove the back cover.
  12. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 12, image 1 of 1
    • The back cover is now removed from the internal hardware.
  13. Sony Cyber-shot DSC-T9 Motherboard Replacement, LCD: step 13, image 1 of 1
    • Use the spudger to pry the LCD from the camera.
  14. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 14, image 1 of 1
    • The LCD is now removed from the camera, although attached by a ribbon at the bottom of the camera.
  15. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 15, image 1 of 2 Sony Cyber-shot DSC-T9 Motherboard Replacement: step 15, image 2 of 2
    Tool used on this step:
    • Flip camera to other side.
    • Use tweezers to peel off black sticker, located in middle of the motherboard.
  16. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 16, image 1 of 2 Sony Cyber-shot DSC-T9 Motherboard Replacement: step 16, image 2 of 2
    • Use pry stick to pop out LCD connector ribbon, also called the ZIF connector.
  17. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 17, image 1 of 1
    • The LCD is now removed from the camera.
  18. Sony Cyber-shot DSC-T9 Motherboard Replacement, CCD Module: step 18, image 1 of 1
    • This is the CCD module.
  19. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 19, image 1 of 1
    • Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • These are the two ribbons.
  20. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 20, image 1 of 1
    • Remove CCD module.
    • You may have to tug on the ribbons to remove the CCD module.
  21. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 21, image 1 of 1
    • The CCD module is now removed from the camera.
  22. Sony Cyber-shot DSC-T9 Motherboard Replacement, AV Port: step 22, image 1 of 2 Sony Cyber-shot DSC-T9 Motherboard Replacement, AV Port: step 22, image 2 of 2
    • These two screws hold in the AV port.
    • Use Phillips screwdriver to remove screws.
  23. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 23, image 1 of 1
    • Remove metal screw plate.
  24. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 24, image 1 of 1
    • Use pry stick to pop off ribbon.
  25. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 25, image 1 of 1
    • Remove AV port from camera.
  26. Sony Cyber-shot DSC-T9 Motherboard Replacement, Motherboard: step 26, image 1 of 2 Sony Cyber-shot DSC-T9 Motherboard Replacement, Motherboard: step 26, image 2 of 2
    • The battery cover is located here.
    • Pull away from camera to remove.
  27. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 27, image 1 of 2 Sony Cyber-shot DSC-T9 Motherboard Replacement: step 27, image 2 of 2
    • Grip on the top and bottom.
    • Pull up and out to remove motherboard and attached parts.
  28. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 28, image 1 of 3 Sony Cyber-shot DSC-T9 Motherboard Replacement: step 28, image 2 of 3 Sony Cyber-shot DSC-T9 Motherboard Replacement: step 28, image 3 of 3
    • Flip motherboard parts to position shown.
    • There are three ribbons still attached to the motherboard.
    • Pull these three ribbons to remove remaining parts from motherboard.
  29. Sony Cyber-shot DSC-T9 Motherboard Replacement: step 29, image 1 of 1
    • The motherboard is now removed from the camera.
3 other people completed this guide.
Stephannie Allen
276 Reputation
10 Guides authored
Clemson, Team 13-1, Benson Spring 2013 Member of Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Members
22 Guides authored
One Comment
Superb,thank you very much !!!
Vedrasco Victor Vasili - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 760
