Sony Cyber-shot DSC-W55 Flash Assembly Replacement
Eddie Lo
Eddie Lo and 6 other contributors
Last updated on December 21, 2020
25 - 35 minutes
Difficult
Action Shots
Incorrect Tools
Needs Better Images
Introduction
Go to step 1
We will explain the steps needed in order to replace a flash assembly.
Tools
Show more…
  1. Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Battery: step 1, image 1 of 2 Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Battery: step 1, image 2 of 2
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 2, image 1 of 2 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 2, image 2 of 2
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Back Case: step 3, image 1 of 2 Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Back Case: step 3, image 2 of 2
    • Using the Phillips #00 screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 4, image 2 of 2
    • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
    • Remove the panel.
  5. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 5, image 1 of 1
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 6, image 1 of 2 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 6, image 2 of 2
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
  7. Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Front Case: step 7, image 1 of 1
    • Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
  8. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 8, image 1 of 3 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 8, image 2 of 3 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 8, image 3 of 3
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
  9. Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Lens: step 9, image 1 of 2 Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Lens: step 9, image 2 of 2
    Tool used on this step:
    • Flip the black secure locks off. Tweezers may be necessary.
    • Detach the two orange cables.
  10. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 10, image 1 of 2 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 10, image 2 of 2
    • Gently pull the lens container out of the camera.
  11. Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Motherboard - First Half: step 11, image 1 of 1
    • Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
  12. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 12, image 1 of 2 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 12, image 2 of 2
    • Remove the two orange cables on the top of the motherboard with tweezers.
    • Lift the motherboard out of its slot.
  13. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 13, image 1 of 2 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 13, image 2 of 2
    • For the AV port, detach the bottom orange cable.
    • For the LCD screen, detach the top orange cable on the right side of the motherboard.
    • For the motherboard, detach all the orange cables.
    • Careful not to damage the red, white, and black wires when lifting the board.
  14. Sony Cyber-shot DSC-W55 Flash Assembly Replacement, LCD Screen: step 14, image 1 of 3 Sony Cyber-shot DSC-W55 Flash Assembly Replacement, LCD Screen: step 14, image 2 of 3 Sony Cyber-shot DSC-W55 Flash Assembly Replacement, LCD Screen: step 14, image 3 of 3
    • Verify the orange cables from the motherboard are removed from the LCD screen.
    • Lift the LCD screen off the hinge.
  15. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 15, image 1 of 3 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 15, image 2 of 3 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 15, image 3 of 3
    • Verify that the LCD screen is attached to the chip on the back on the camera.
    • Remove the dial from the back of the camera. It pops right off very easily.
    • Remove the screw using a Phillips #00 Screwdriver from the camera.
  16. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 16, image 1 of 2 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 16, image 2 of 2
    • Remove the orange cable that is attached between the top of the camera and the chip. It should slide straight out with a little bit of force.
    • Remove the chip and the LCD screen now from the camera.
    • The chip may need a slight upward tug with a fingernail or tweezer.
  17. Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Flash Assembly: step 17, image 1 of 2 Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Flash Assembly: step 17, image 2 of 2
    • Verify that the orange cables from the top piece are removed from the motherboard.
    • Remove the screw using a Phillips #00 Screwdriver on the upper part of the back side.
    • Pull the top off slowly and with caution. It is still slightly attached and may need a little force.
  18. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 18, image 1 of 2 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: step 18, image 2 of 2
    • Slowly twist out the flash assembly.
    • It is attached to the hinge so a little force is necessary.
4 other people completed this guide.
Eddie Lo
334 Reputation
4 Guides authored
Cal Poly, Team 9-20, Regan Fall 2010 Member of Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
5 Members
18 Guides authored
One Comment
LensK pati lagwana hai
Sahil Singh - Reply
Past 24 Hours: 14
Past 7 Days: 15
Past 30 Days: 34
All Time: 9,225
