Introduction
We will provide instructions to follow to remove and thus replace the motherboard.
Slide the battery cover in the direction the arrow points.
Pull the battery cover towards you.
Using the Phillips #00 screwdriver, remove the two screws from the caution panel.
Remove that panel.
Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
Tool used on this step:Tweezers$4.99
Flip the black secure locks off. Tweezers may be necessary.
Detach the two orange cables.
Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
Verify the orange cables from the motherboard are removed from the LCD screen.
Lift the LCD screen off the hinge.
Verify that the orange cables from the top piece are removed from the motherboard.
Remove the screw using a Phillips #00 Screwdriver on the upper part of the back side.
Verify the red, white, and black cables are still attached to the camera.
Remove the screw using a Phillips #00 Screwdriver near the AV port
One Comment
Si I' étais une forme d'objet technique, il me plairait d'être ainsi démonté-remonté.
Mais I ne suis qu'une dite forme de Grand mammifère placentaire respirant en dite basse couche atmosphérique planétaire.
I ne sais ce qu'est l'Intelligence, mais nonobstant que de dite finesse dans ces dites activités anatomiques-physiologiques explicatives.
Merci
Christian
