Sony Cybershot DSC-W80 Lens Replacement
  1. Sony Cybershot DSC-W80 Lens Replacement, Battery: step 1, image 1 of 2 Sony Cybershot DSC-W80 Lens Replacement, Battery: step 1, image 2 of 2
    • Open the battery cover by sliding it towards you.
  2. Sony Cybershot DSC-W80 Lens Replacement: step 2, image 1 of 1
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: step 3, image 1 of 3 Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: step 3, image 2 of 3 Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: step 3, image 3 of 3
    • Remove the eight Phillips #000 screws.
  4. Sony Cybershot DSC-W80 Lens Replacement: step 4, image 1 of 1
    • Remove the single Phillips #000 screw found next to the battery latch.
  5. Sony Cybershot DSC-W80 Lens Replacement: step 5, image 1 of 2 Sony Cybershot DSC-W80 Lens Replacement: step 5, image 2 of 2
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  6. Sony Cybershot DSC-W80 Lens Replacement, Lens: step 6, image 1 of 3 Sony Cybershot DSC-W80 Lens Replacement, Lens: step 6, image 2 of 3 Sony Cybershot DSC-W80 Lens Replacement, Lens: step 6, image 3 of 3
    • Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Once disconnected, use your fingers to lift lens out of the frame.
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 33
All Time: 695
