Sony Cybershot DSC-W830 Motherboard Replacement
  1. Sony Cybershot DSC-W830 Motherboard Replacement, Battery: step 1, image 1 of 2 Sony Cybershot DSC-W830 Motherboard Replacement, Battery: step 1, image 2 of 2
    • Open the battery cover by sliding it towards you.
  2. Sony Cybershot DSC-W830 Motherboard Replacement: step 2, image 1 of 1
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: step 3, image 1 of 3 Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: step 3, image 2 of 3 Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: step 3, image 3 of 3
    • Remove the eight Phillips #000 screws.
  4. Sony Cybershot DSC-W830 Motherboard Replacement: step 4, image 1 of 1
    • Remove the single Phillips #000 screw found next to the battery latch.
  5. Sony Cybershot DSC-W830 Motherboard Replacement: step 5, image 1 of 2 Sony Cybershot DSC-W830 Motherboard Replacement: step 5, image 2 of 2
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  6. Sony Cybershot DSC-W830 Motherboard Replacement, Lens: step 6, image 1 of 3 Sony Cybershot DSC-W830 Motherboard Replacement, Lens: step 6, image 2 of 3 Sony Cybershot DSC-W830 Motherboard Replacement, Lens: step 6, image 3 of 3
    • Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Once disconnected, use your fingers to lift lens out of the frame.
  7. Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: step 7, image 1 of 3 Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: step 7, image 2 of 3 Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: step 7, image 3 of 3
    • Lift the power button board up off of the daughterboard.
  8. Sony Cybershot DSC-W830 Motherboard Replacement: step 8, image 1 of 1
    • Remove the single Phillips #000 screw.
    • Use your hands to remove the blue daughterboard.
  9. Sony Cybershot DSC-W830 Motherboard Replacement: step 9, image 1 of 2 Sony Cybershot DSC-W830 Motherboard Replacement: step 9, image 2 of 2
    • Flip the camera around.
    • Remove the black and orange ribbon cables.
  10. Sony Cybershot DSC-W830 Motherboard Replacement, Motherboard: step 10, image 1 of 1
    • Remove the two remaining ribbon cables.
    • Pull the motherboard from the camera.
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 14
All Time: 513
