1998 Nissan Frontier Fuel Filter Replacement
  1. 1998 Nissan Frontier Fuel Filter Replacement, Fuel Filter: step 1, image 1 of 2 1998 Nissan Frontier Fuel Filter Replacement, Fuel Filter: step 1, image 2 of 2
    • Before getting under the vehicle to begin replacement. Apply the emergency hand brake to prevent the vehicle from rolling.
  2. 1998 Nissan Frontier Fuel Filter Replacement: step 2, image 1 of 2 1998 Nissan Frontier Fuel Filter Replacement: step 2, image 2 of 2
    • Locate the fuel filter under the passenger side of the cabin, mounted on the inside frame rail.
  3. 1998 Nissan Frontier Fuel Filter Replacement: step 3, image 1 of 1
    • Place a drain pan underneath the fuel filter to collect any excess fuel that leaks from the fuel filter and lines during disassembly.
  4. 1998 Nissan Frontier Fuel Filter Replacement: step 4, image 1 of 1
    • Using the 10 mm socket wrench, loosen the bolt on the clamp that holds the fuel filter in place.
  5. 1998 Nissan Frontier Fuel Filter Replacement: step 5, image 1 of 1
    • Using vice grips, apply them to the fuel lines on both sides of the fuel filter before removing the hoses. This will prevent any excess fuel from leaking out of the lines.
    • Remember to leave about 4 inches of room to slide the hose clamps off the fuel filter fitting.
  6. 1998 Nissan Frontier Fuel Filter Replacement: step 6, image 1 of 1
    • Using a Phillips 3 screwdriver, loosen the screws on the hose clamps located on both sides of the fuel filter.
  7. 1998 Nissan Frontier Fuel Filter Replacement: step 7, image 1 of 1
    • Slide the fuel line clamps off both sides of the fuel filter fittings.
  8. 1998 Nissan Frontier Fuel Filter Replacement: step 8, image 1 of 2 1998 Nissan Frontier Fuel Filter Replacement: step 8, image 2 of 2
    • Using a flat head screw driver, work loose the fuel line if it has been on the fitting for many years. Using your hands or a pair of pliers gently rotate and pull on the line to remove the fuel line completely from the fitting.
  9. 1998 Nissan Frontier Fuel Filter Replacement: step 9, image 1 of 1
    • Remove the old fuel filter from the clamp in which it should slide out since it is already loose.
  10. 1998 Nissan Frontier Fuel Filter Replacement: step 10, image 1 of 1
    • Put the fuel line on the filter that is closest to the front of the vehicle first.
    • This will allow you to have more space while installing the other hose onto the other end of the fuel filter. Installing the hoses onto the fittings can be a bit tedious so you may have to apply some pressure to fully have the fuel line back on.
  11. 1998 Nissan Frontier Fuel Filter Replacement: step 11, image 1 of 1
    • Put the fuel filter back in the clamp.
  12. 1998 Nissan Frontier Fuel Filter Replacement: step 12, image 1 of 1
    • Place the other fuel line on the fuel filter fitting.
  13. 1998 Nissan Frontier Fuel Filter Replacement: step 13, image 1 of 1
    • Remove the vice clamps.
  14. 1998 Nissan Frontier Fuel Filter Replacement: step 14, image 1 of 1
    • Slide the hose clamps back on the fuel filter fittings over the fuel lines on both sides of the fuel filters.
  15. 1998 Nissan Frontier Fuel Filter Replacement: step 15, image 1 of 1
    • Using the Phillips 3 screwdriver, tighten the hose clamps on the fuel line until it is tight without over tightening cutting the fuel line.
  16. 1998 Nissan Frontier Fuel Filter Replacement: step 16, image 1 of 1
    • Using the 10 mm socket wrench, tighten the clamp that holds the fuel filter into place.
This is a good entry level fix to get your feet wet with working on vehicles.
Alex Eisenbraun
253 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 42
All Time: 4,119
