Sony DSC-RX100MA Image Sensor Replacement
  1. Sony DSC-RX100MA Image Sensor Replacement, Back Cover: step 1, image 1 of 3 Sony DSC-RX100MA Image Sensor Replacement, Back Cover: step 1, image 2 of 3 Sony DSC-RX100MA Image Sensor Replacement, Back Cover: step 1, image 3 of 3
    • Remove battery by sliding the tab to open the cover
  2. Sony DSC-RX100MA Image Sensor Replacement: step 2, image 1 of 3 Sony DSC-RX100MA Image Sensor Replacement: step 2, image 2 of 3 Sony DSC-RX100MA Image Sensor Replacement: step 2, image 3 of 3
    • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
    • All screws in the camera can be removed with the PH 0 driver head.
  3. Sony DSC-RX100MA Image Sensor Replacement: step 3, image 1 of 3 Sony DSC-RX100MA Image Sensor Replacement: step 3, image 2 of 3 Sony DSC-RX100MA Image Sensor Replacement: step 3, image 3 of 3
    • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
    • Remove the marked 2.5 mm screws with the screwdriver
  4. Sony DSC-RX100MA Image Sensor Replacement: step 4, image 1 of 2 Sony DSC-RX100MA Image Sensor Replacement: step 4, image 2 of 2
    • Using the plastic opening tools, carefully pry off the bottom plate.
    • Do not pull too hard as you may break the plastic casing.
  5. Sony DSC-RX100MA Image Sensor Replacement: step 5, image 1 of 3 Sony DSC-RX100MA Image Sensor Replacement: step 5, image 2 of 3 Sony DSC-RX100MA Image Sensor Replacement: step 5, image 3 of 3
    • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
    • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
  6. Sony DSC-RX100MA Image Sensor Replacement: step 6, image 1 of 2 Sony DSC-RX100MA Image Sensor Replacement: step 6, image 2 of 2
    • Remove the back cover
  7. Sony DSC-RX100MA Image Sensor Replacement, Screen: step 7, image 1 of 3 Sony DSC-RX100MA Image Sensor Replacement, Screen: step 7, image 2 of 3 Sony DSC-RX100MA Image Sensor Replacement, Screen: step 7, image 3 of 3
    • Move side panel to get access to screws
    • Remove two screws (black 2.5mm) with PH #0 screwdriver
  8. Sony DSC-RX100MA Image Sensor Replacement: step 8, image 1 of 2 Sony DSC-RX100MA Image Sensor Replacement: step 8, image 2 of 2
    • Remove back panel assembly while still keeping ribbon cable attached
    • Be very gentle and care not to tear the gold ribbon cable. This will be a common theme throughout these replacement guides.
  9. Sony DSC-RX100MA Image Sensor Replacement: step 9, image 1 of 2 Sony DSC-RX100MA Image Sensor Replacement: step 9, image 2 of 2
    • Carefully unplug ribbon connector to fully detach LCD screen assembly from camera
  10. Sony DSC-RX100MA Image Sensor Replacement, Image Sensor: step 10, image 1 of 2 Sony DSC-RX100MA Image Sensor Replacement, Image Sensor: step 10, image 2 of 2
    • Using the Philips Screwdriver, remove the screw (black 3mm) located on the copper casing.
  11. Sony DSC-RX100MA Image Sensor Replacement: step 11, image 1 of 3 Sony DSC-RX100MA Image Sensor Replacement: step 11, image 2 of 3 Sony DSC-RX100MA Image Sensor Replacement: step 11, image 3 of 3
    • Using the plastic opening tools, carefully pry off the copper casing at the two pictured points.
    • Remove casing.
  12. Sony DSC-RX100MA Image Sensor Replacement: step 12, image 1 of 3 Sony DSC-RX100MA Image Sensor Replacement: step 12, image 2 of 3 Sony DSC-RX100MA Image Sensor Replacement: step 12, image 3 of 3
    • Using the Philips screwdriver, remove the three (silver 3mm) screws
    • Remove the screw (silver 2mm) from the upper right hand corner
  13. Sony DSC-RX100MA Image Sensor Replacement: step 13, image 1 of 3 Sony DSC-RX100MA Image Sensor Replacement: step 13, image 2 of 3 Sony DSC-RX100MA Image Sensor Replacement: step 13, image 3 of 3
    • Place your finger into the battery port and push up on the SD card holder to push it out of its socket.
    • Give it a little wiggle and you should feel the SD card holder come out.
  14. Sony DSC-RX100MA Image Sensor Replacement: step 14, image 1 of 1
    • Now you can remove the marked gold ribbon cable from the SD card holder.
    • Utilize extreme caution while removing because the ribbon cables are extremely fragile and important to the camera.
Isaiah De Leon
439 Reputation
3 Guides authored
Cal Poly, Team 21-1, Maness Winter 2017 Member of Cal Poly, Team 21-1, Maness Winter 2017
CPSU-MANESS-W17S21G1
5 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 29
All Time: 3,709
