Sony DVP-FX730 Cover Replacement
  1. Sony DVP-FX730 Cover Replacement, Cover: step 1, image 1 of 1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Cover Replacement: step 2, image 1 of 1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Cover Replacement: step 3, image 1 of 1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Cover Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
Rogelio Garcia
22 Reputation
1 Guide authored
Cal Poly, Team 11-21, Maness Winter 2012 Member of Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 1,592
