Sony DVP-FX730 Laser Replacement
  1. Sony DVP-FX730 Laser Replacement, Cover: step 1, image 1 of 1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Laser Replacement: step 2, image 1 of 1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Laser Replacement: step 3, image 1 of 1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Laser Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
  5. Sony DVP-FX730 Laser Replacement, Laser: step 5, image 1 of 2 Sony DVP-FX730 Laser Replacement, Laser: step 5, image 2 of 2
    • Remove the large connector.
    • Remove the small connector.
  6. Sony DVP-FX730 Laser Replacement: step 6, image 1 of 1
    • Remove Philips screws with the #0 Philips Screwdriver.
  7. Sony DVP-FX730 Laser Replacement: step 7, image 1 of 1
    • Lift up the black piece connected to the wires.
    • Lift gently because the ribbon cable is attached to the bottom.
  8. Sony DVP-FX730 Laser Replacement: step 8, image 1 of 2 Sony DVP-FX730 Laser Replacement: step 8, image 2 of 2
    • Unlock the lock clip
  9. Sony DVP-FX730 Laser Replacement: step 9, image 1 of 1
    • Remove the T6 screws with the T6 screwdriver.
  10. Sony DVP-FX730 Laser Replacement: step 10, image 1 of 1
    Buy
    • Gently pull the rods out with tweezers.
    • Be sure the laser is out of the way so that the rods can be removed.
  11. Sony DVP-FX730 Laser Replacement: step 11, image 1 of 2 Sony DVP-FX730 Laser Replacement: step 11, image 2 of 2
    • Pull laser off of the rods.
    • Be careful when removing the rods because a fragile metal piece may break.
  12. Sony DVP-FX730 Laser Replacement: step 12, image 1 of 1
    • The laser is now removed.
Oliver Woolsoncroft
81 Reputation
2 Guides authored
Cal Poly, Team 11-21, Maness Winter 2012 Member of Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Members
5 Guides authored
One Comment
where do I buy the lens?
mnmmacd - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 4,799
