Sony DVP-FX730 Screen Replacement
  1. Sony DVP-FX730 Screen Replacement, Monitor: step 1, image 1 of 2 Sony DVP-FX730 Screen Replacement, Monitor: step 1, image 2 of 2
    • Use your hand to remove the small back cover by gently pulling upward.
  2. Sony DVP-FX730 Screen Replacement: step 2, image 1 of 1
    • Using a screwdriver, remove the two 12 mm pan head screws.
  3. Sony DVP-FX730 Screen Replacement: step 3, image 1 of 1
    • The screen should now detach from the primary device.
    • The wires, indicated with a blue box, will still connect the screen.
  4. Sony DVP-FX730 Screen Replacement: step 4, image 1 of 2 Sony DVP-FX730 Screen Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the wires attached to the white base using tweezers to pull them up.
  5. Sony DVP-FX730 Screen Replacement: step 5, image 1 of 2 Sony DVP-FX730 Screen Replacement: step 5, image 2 of 2
    • Referring back to Step 8, do the same with the wires attached to the black base.
  6. Sony DVP-FX730 Screen Replacement: step 6, image 1 of 1
    • The screen should now be completely separated from the main device.
  7. Sony DVP-FX730 Screen Replacement, Screen: step 7, image 1 of 1
    • Remove the four rubber feet and the screws beneath.
    • Remove the two exposed screws on the left side.
    • Pull back the cables until the screw is visible.
  8. Sony DVP-FX730 Screen Replacement: step 8, image 1 of 1
    • Using the spudger, separate the top and bottom covers.
  9. Sony DVP-FX730 Screen Replacement: step 9, image 1 of 1
    • Identify the gray back of the screen.
  10. Sony DVP-FX730 Screen Replacement: step 10, image 1 of 1
    • Remove the screws.
  11. Sony DVP-FX730 Screen Replacement: step 11, image 1 of 1
    • Remove the metal plates.
  12. Sony DVP-FX730 Screen Replacement: step 12, image 1 of 2 Sony DVP-FX730 Screen Replacement: step 12, image 2 of 2
    Buy
    • Using spudger, push the lock clips to unlock the ribbon cable.
    • Using tweezers, pull the connector loose.
  13. Sony DVP-FX730 Screen Replacement: step 13, image 1 of 2 Sony DVP-FX730 Screen Replacement: step 13, image 2 of 2
    • Place your hand on the front of the screen and push upwards.
2 other people completed this guide.
Oliver Woolsoncroft
81 Reputation
2 Guides authored
Cal Poly, Team 11-21, Maness Winter 2012 Member of Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 30
All Time: 3,065
