Introduction
Follow this guide to replace the L1 and R1 trigger buttons on a Sony PlayStation 5 DualSense controller.
Disconnect and power down your controller before starting your repair.
With one hand, grip the controller and use your thumb to hold down the left trigger.
With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
8 other people completed this guide.
3 Comments
It is easier to remove L1/R1 by going from below than by from above- without any damages.
Does the spudger dent or mark the button when doing this?
My replacement R1 button is different enough to not fit. Fins around center sleeve are wider. So there must have been a design change at some point.
