Sony DualSense Controller Microphone Replacement
  1. Sony DualSense Controller Microphone Replacement, Unclip the right end of the middle trim: step 1, image 1 of 2 Sony DualSense Controller Microphone Replacement, Unclip the right end of the middle trim: step 1, image 2 of 2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. Sony DualSense Controller Microphone Replacement, Unclip the lower-right edge of the middle trim: step 2, image 1 of 3 Sony DualSense Controller Microphone Replacement, Unclip the lower-right edge of the middle trim: step 2, image 2 of 3 Sony DualSense Controller Microphone Replacement, Unclip the lower-right edge of the middle trim: step 2, image 3 of 3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. Sony DualSense Controller Microphone Replacement, Unclip the left end of the middle trim: step 3, image 1 of 2 Sony DualSense Controller Microphone Replacement, Unclip the left end of the middle trim: step 3, image 2 of 2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. Sony DualSense Controller Microphone Replacement, Unclip the lower-left edge of the middle trim: step 4, image 1 of 3 Sony DualSense Controller Microphone Replacement, Unclip the lower-left edge of the middle trim: step 4, image 2 of 3 Sony DualSense Controller Microphone Replacement, Unclip the lower-left edge of the middle trim: step 4, image 3 of 3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. Sony DualSense Controller Microphone Replacement, Remove the middle trim: step 5, image 1 of 3 Sony DualSense Controller Microphone Replacement, Remove the middle trim: step 5, image 2 of 3 Sony DualSense Controller Microphone Replacement, Remove the middle trim: step 5, image 3 of 3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. Sony DualSense Controller Microphone Replacement, Remove the L1 button: step 6, image 1 of 3 Sony DualSense Controller Microphone Replacement, Remove the L1 button: step 6, image 2 of 3 Sony DualSense Controller Microphone Replacement, Remove the L1 button: step 6, image 3 of 3
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
  7. Sony DualSense Controller Microphone Replacement, Remove the R1 button: step 7, image 1 of 3 Sony DualSense Controller Microphone Replacement, Remove the R1 button: step 7, image 2 of 3 Sony DualSense Controller Microphone Replacement, Remove the R1 button: step 7, image 3 of 3
    • Repeat the previous step to remove the R1 button.
  8. Sony DualSense Controller Microphone Replacement, Remove the rear case screws: step 8, image 1 of 2 Sony DualSense Controller Microphone Replacement, Remove the rear case screws: step 8, image 2 of 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. Sony DualSense Controller Microphone Replacement: step 9, image 1 of 2 Sony DualSense Controller Microphone Replacement: step 9, image 2 of 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. Sony DualSense Controller Microphone Replacement, Separate the rear case: step 10, image 1 of 3 Sony DualSense Controller Microphone Replacement, Separate the rear case: step 10, image 2 of 3 Sony DualSense Controller Microphone Replacement, Separate the rear case: step 10, image 3 of 3
    • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
  11. Sony DualSense Controller Microphone Replacement: step 11, image 1 of 3 Sony DualSense Controller Microphone Replacement: step 11, image 2 of 3 Sony DualSense Controller Microphone Replacement: step 11, image 3 of 3
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
  12. Sony DualSense Controller Microphone Replacement: step 12, image 1 of 3 Sony DualSense Controller Microphone Replacement: step 12, image 2 of 3 Sony DualSense Controller Microphone Replacement: step 12, image 3 of 3
    • Repeat the previous step on the right edge to release its clips.
  13. Sony DualSense Controller Microphone Replacement: step 13, image 1 of 2 Sony DualSense Controller Microphone Replacement: step 13, image 2 of 2
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
  14. Sony DualSense Controller Microphone Replacement, Remove the rear case: step 14, image 1 of 1
    • Remove the rear case.
  15. Sony DualSense Controller Microphone Replacement, Disconnect the battery: step 15, image 1 of 2 Sony DualSense Controller Microphone Replacement, Disconnect the battery: step 15, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Grip the connector, not the wires, when disconnecting.
  16. Sony DualSense Controller Microphone Replacement, Remove the battery: step 16, image 1 of 2 Sony DualSense Controller Microphone Replacement, Remove the battery: step 16, image 2 of 2
    • Lift the battery straight out of the battery bracket.
  17. Sony DualSense Controller Microphone Replacement, Remove the lower microphone: step 17, image 1 of 2 Sony DualSense Controller Microphone Replacement, Remove the lower microphone: step 17, image 2 of 2
    Buy
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
  18. Sony DualSense Controller Microphone Replacement, Remove the battery bracket: step 18, image 1 of 2 Sony DualSense Controller Microphone Replacement, Remove the battery bracket: step 18, image 2 of 2
    • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
  19. Sony DualSense Controller Microphone Replacement: step 19, image 1 of 2 Sony DualSense Controller Microphone Replacement: step 19, image 2 of 2
    • Lift the battery bracket out of the motherboard.
  20. Sony DualSense Controller Microphone Replacement, Disconnect the right trigger assembly: step 20, image 1 of 2 Sony DualSense Controller Microphone Replacement, Disconnect the right trigger assembly: step 20, image 2 of 2
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
    • Do not completely remove the ribbon cable yet.
  21. Sony DualSense Controller Microphone Replacement: step 21, image 1 of 2 Sony DualSense Controller Microphone Replacement: step 21, image 2 of 2
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
    • Remove the ribbon cable.
  22. Sony DualSense Controller Microphone Replacement, Disconnect the left trigger assembly: step 22, image 1 of 2 Sony DualSense Controller Microphone Replacement, Disconnect the left trigger assembly: step 22, image 2 of 2
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
  23. Sony DualSense Controller Microphone Replacement: step 23, image 1 of 2 Sony DualSense Controller Microphone Replacement: step 23, image 2 of 2
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
  24. Sony DualSense Controller Microphone Replacement, Disconnect the upper microphone: step 24, image 1 of 2 Sony DualSense Controller Microphone Replacement, Disconnect the upper microphone: step 24, image 2 of 2
    • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
  25. Sony DualSense Controller Microphone Replacement, Disconnect the touchpad: step 25, image 1 of 2 Sony DualSense Controller Microphone Replacement, Disconnect the touchpad: step 25, image 2 of 2
    • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
  26. Sony DualSense Controller Microphone Replacement, Lift out the motherboard: step 26, image 1 of 3 Sony DualSense Controller Microphone Replacement, Lift out the motherboard: step 26, image 2 of 3 Sony DualSense Controller Microphone Replacement, Lift out the motherboard: step 26, image 3 of 3
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints.
    • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
  27. Sony DualSense Controller Microphone Replacement, Remove the speaker: step 27, image 1 of 3 Sony DualSense Controller Microphone Replacement, Remove the speaker: step 27, image 2 of 3 Sony DualSense Controller Microphone Replacement, Remove the speaker: step 27, image 3 of 3
    Buy
    • Use a pair of tweezers or your fingers to remove the speaker from the controller midframe.
    • Be sure to reinstall the speaker in the correct orientation with the foam pad on the left side and the gold contact points on the right.
  28. Sony DualSense Controller Microphone Replacement, Flip over the controller: step 28, image 1 of 3 Sony DualSense Controller Microphone Replacement, Flip over the controller: step 28, image 2 of 3 Sony DualSense Controller Microphone Replacement, Flip over the controller: step 28, image 3 of 3
    • Carefully flip over the controller and motherboard.
  29. Sony DualSense Controller Microphone Replacement, Remove the upper microphone: step 29, image 1 of 2 Sony DualSense Controller Microphone Replacement, Remove the upper microphone: step 29, image 2 of 2
    Buy
    • Use a pair of tweezers or your fingers to remove the upper microphone from the front case.
    • Feed the microphone ribbon cable out carefully, the pull tab may catch on the front case.
8 other people completed this guide.
Sam Omiotek
94,264 Reputation
290 Guides authored
3 Guide Comments
Does this fix issues with the headphone-port as well? ( such as headphones and attached mics not properly resting flush)
Malik Blassingale - Reply
I broke my upper microphone ribbon cable while installing a controller mod kit. The cable is difficult to position, extremely fragile around the mount hole, and it can only take a little bit of stress before failure.
Regardless, all of the buttons still work and the mod kit functions properly. I don't really care if my controller has full microphone functionality lmao
Payton Fisher - Reply
I was replacing mic sets for BDM-010 and BDM-020 and in both cases steps 15 to 25 were unnecessary. You don't even have to do anything differently - just skip this steps. Mind me if I'm wrong.
Marcin Malec - Reply
Past 24 Hours: 34
Past 7 Days: 270
Past 30 Days: 1,361
All Time: 37,178
