Sony DualSense Controller Touchpad Replacement
  1. Sony DualSense Controller Touchpad Replacement, Unclip the right end of the middle trim: step 1, image 1 of 2 Sony DualSense Controller Touchpad Replacement, Unclip the right end of the middle trim: step 1, image 2 of 2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. Sony DualSense Controller Touchpad Replacement, Unclip the lower-right edge of the middle trim: step 2, image 1 of 3 Sony DualSense Controller Touchpad Replacement, Unclip the lower-right edge of the middle trim: step 2, image 2 of 3 Sony DualSense Controller Touchpad Replacement, Unclip the lower-right edge of the middle trim: step 2, image 3 of 3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. Sony DualSense Controller Touchpad Replacement, Unclip the left end of the middle trim: step 3, image 1 of 2 Sony DualSense Controller Touchpad Replacement, Unclip the left end of the middle trim: step 3, image 2 of 2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. Sony DualSense Controller Touchpad Replacement, Unclip the lower-left edge of the middle trim: step 4, image 1 of 3 Sony DualSense Controller Touchpad Replacement, Unclip the lower-left edge of the middle trim: step 4, image 2 of 3 Sony DualSense Controller Touchpad Replacement, Unclip the lower-left edge of the middle trim: step 4, image 3 of 3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. Sony DualSense Controller Touchpad Replacement, Remove the middle trim: step 5, image 1 of 3 Sony DualSense Controller Touchpad Replacement, Remove the middle trim: step 5, image 2 of 3 Sony DualSense Controller Touchpad Replacement, Remove the middle trim: step 5, image 3 of 3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. Sony DualSense Controller Touchpad Replacement, Remove the L1 button: step 6, image 1 of 3 Sony DualSense Controller Touchpad Replacement, Remove the L1 button: step 6, image 2 of 3 Sony DualSense Controller Touchpad Replacement, Remove the L1 button: step 6, image 3 of 3
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
    Tried prying from the front of the buttons as pictured and my spudger broke off in the gap. A video I watched showed them being pried off from the back (between the R1/R2 and L1/L2 buttons) which seemed much easier.
    Lora Singleton - Reply
    Agree with Lora's comment above. I was able to use an old credit card to take L1/R1 out this way. I pressed down the L2/R2 button to create space to work in, then came in from between L1/L2 and R1/R2. It's easy to pop one of the outer corners first then you can work the credit card around the top and the rest falls out.
    darkstar448 - Reply
    Man, if I'd just read the thumb part...
    caldugen - Reply
  7. Sony DualSense Controller Touchpad Replacement, Remove the R1 button: step 7, image 1 of 3 Sony DualSense Controller Touchpad Replacement, Remove the R1 button: step 7, image 2 of 3 Sony DualSense Controller Touchpad Replacement, Remove the R1 button: step 7, image 3 of 3
    • Repeat the previous step to remove the R1 button.
    to save a few bucks, the L1 and R1 buttons can be removed without the use of the spudger tool by using any thin prying tool and just pry the buttons from the bottom instead of the top
    Alan Peng - Reply
    What I didn't see addressed anywhere (here or in other similar articles) is that replacement R1 / L1 buttons can be differ enough to be un-usable depending on which model your ps5 controller is. The ones I ordered don't fit and now I can't find a way to be sure I get the right ones because few know there's even a difference.
    Walt Mather - Reply
    Did you already figured it out? The version the we need yo use?, We are in the same situation here.
    Gerald Ross Rodriguez -
  8. Sony DualSense Controller Touchpad Replacement, Remove the rear case screws: step 8, image 1 of 2 Sony DualSense Controller Touchpad Replacement, Remove the rear case screws: step 8, image 2 of 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. Sony DualSense Controller Touchpad Replacement: step 9, image 1 of 2 Sony DualSense Controller Touchpad Replacement: step 9, image 2 of 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. Sony DualSense Controller Touchpad Replacement, Separate the rear case: step 10, image 1 of 3 Sony DualSense Controller Touchpad Replacement, Separate the rear case: step 10, image 2 of 3 Sony DualSense Controller Touchpad Replacement, Separate the rear case: step 10, image 3 of 3
    • Be gently when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
  11. Sony DualSense Controller Touchpad Replacement: step 11, image 1 of 3 Sony DualSense Controller Touchpad Replacement: step 11, image 2 of 3 Sony DualSense Controller Touchpad Replacement: step 11, image 3 of 3
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
  12. Sony DualSense Controller Touchpad Replacement: step 12, image 1 of 3 Sony DualSense Controller Touchpad Replacement: step 12, image 2 of 3 Sony DualSense Controller Touchpad Replacement: step 12, image 3 of 3
    • Repeat the previous step on the right edge to release its clips.
  13. Sony DualSense Controller Touchpad Replacement: step 13, image 1 of 2 Sony DualSense Controller Touchpad Replacement: step 13, image 2 of 2
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
  14. Sony DualSense Controller Touchpad Replacement, Remove the rear case: step 14, image 1 of 1
    • Remove the rear case.
    There are four more clips/hooks hidden in the seams along the outer sides of the handles. If you pull open the controller as shown in this step, then you will shear off the two tiny clips which are right next to the R1 and L1 buttons.
    Therefore, you should first release those clips by prying the seams open sideways.
    I noticed this with the updated design of the controller, not sure whether the hooks are present on the first version.
    The hooks are not critical for the integrity of the controller as the two halves are held together by the screws hidden under the buttons. The damage does show that the controller has been taken apart.
    Nick - Reply
    Thought I'd clarify: The clips next to the L1 and R1 are on the outer side from the L1 and R1 buttons, I'd suggest zooming in on the picture to see them. They're quite easy to break, but also easy to remove using the plastic spudger along the seam, bending the bottom cover outwards
    Franz Rolfsvaag -
    I am still strugling to find the clips. Could someone point them out in the image with a screen shot or something like that.
    aGingerThing - Reply
    I keep getting stuck at this step too with the new DualSense CFI-ZCT1WA revision. The top and bottom shells seem like they are fused together next to L1/R1 but I can't seem to be able to find where these hidden clips are located. My controller is still in warranty so I don't want to break them in case I can't fix my issue.
    I tried this but it seems that the you need a lot of force and I ended up bending the tip of my spudger. Are you sure it's not the top cover that you need to pry away? The bottom cover has a ridge to make sure it's under the top cover so it's not easy to bend outwards.
    @samomio I think there needs to be a step added for these new clips.
    robplease - Reply
    Ok, not seeing a lot of motion on this request, so I've uploaded photos of the hooks to imgur.
    Here ya go: https://imgur.io/a/7NWmQi5
    Sean Murphy - Reply
    Life save Sean. Appreciate the image.
    Vili - Reply
    This guide really needs an update on this. I had a really hard time getting the forward clips to release even after referring to the comments above. Pretty sure I broke them in the end. No big deal but would be great if the iFixit experts could work out a good method for releasing them.
    Marcus Harvey - Reply
    I finally figure it out!!
    The hidden clip is very tricky but once you understand how it works it is easy to remove.
    Use Sean's picture: https://imgur.io/a/7NWmQi5
    What sean is showing, is actually the bottom shell of the seam.
    To disassemble
    1. Use the flat side of the spudger, pry the bottom seam OUTWARDS near the R1/L1 button hole.
    2. (most important) While prying the bottom shell seam outwards, push your thumb on the upper shell and push outward as well (you can do this by applying pressure from the removed R1/L1 button hole towards the seam. And then it will disassemble automatically
    And that's it!
    Penn - Reply
    updated instruction:
    To disassemble
    2. (most important) While prying the bottom shell seam outwards, hold your thumb on the upper shell as anchor and then use your other finger to pry the bottom edge of the controller up away from the shell. If you are doing the first step, then don't worry about breaking the clip, just force it open. And then it will disassemble automatically
    And that's it!
    Penn - Reply
    Yes! Thanks a bunch Penn. That did the trick! Much appreciated
    Sean -
    I managed to do it just by pulling harder than what I was already doing. And I don't think I broke anything. So, for me at least, the technique described in this guide worked.
    Riedweg Guillaume - Reply
    The video linked below clearly shows how to open the controllers with the extra clips near the L1/R1 areas.
    See a video here by How To X on YouTube... https://youtu.be/djIvRoclr_E?si=dKFpQCZe...
    Jason Z - Reply
    I really struggled with releasing the rest of the back panel (close to the shoulder buttons.) What finally seemed to do the trick for me, was doing both sides at once with upward turning motion of the back panel with the shoulder buttons approximately at the axis. Trying to release just one side and then the other felt impossible without potentially breaking the case.
    dborba - Reply
    This was what did it for me
    Matthew Williamson -
  15. Sony DualSense Controller Touchpad Replacement, Disconnect the battery: step 15, image 1 of 2 Sony DualSense Controller Touchpad Replacement, Disconnect the battery: step 15, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Grip the connector, not the wires, when disconnecting.
    Tweezers aren't gonna grip that the way you need.
    Leif DeWolf - Reply
    For those having trouble using tweezers to pull out the connector, you can grab below the lip of the connector and use the controller as a lever to pull it up as seen here DualSense Controller v2 Battery Replacement
    This little trick helped me so much and I believe it should be shown on this guide as well.
    Ezra Worthington - Reply
    Tweezers is too weak for this. I use my finger nails after removing the battery from the slot, straighten the cable lines and slowly wiggle it out.
    Penn - Reply
  16. Sony DualSense Controller Touchpad Replacement, Remove the battery: step 16, image 1 of 2 Sony DualSense Controller Touchpad Replacement, Remove the battery: step 16, image 2 of 2
    • Lift the battery straight out of the battery bracket.
  17. Sony DualSense Controller Touchpad Replacement, Remove the lower microphone: step 17, image 1 of 2 Sony DualSense Controller Touchpad Replacement, Remove the lower microphone: step 17, image 2 of 2
    Buy
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
    These ribbon cables have small tabs on either side you can use to help pull out the cable. You can slightly pull up, alternating between the two sides, to slowly wiggle the connector out.
    Tran Anh Nguyen - Reply
    Might be a rookie mistake, but DO NOT REMOVE THE WHITE BRACKETS, only the ribbon! If you do, you’ll have an awful time putting it back and will most likely mess it up. Yes I did.
    Joris D - Reply
    I tried to use metal tweezers to pull this out and absolutely shredded the ribbon in the process. It's just a microphone so I wouldn't expect it to matter but now none of the games get any input from the controller even though the controller works fine in the home menu 🥲
    Probably just use your fingers if you have the dexterity for it.
    Grey - Reply
    As others have said, try to only remove the ribbon and not the white connector. I'd advise holding down the white connector with something (perhaps your prying tool or finger) as you pull the ribbon out gently with the tweezers.
    Best to avoid pulling out the white connector if possible - but its not the end of the world if you do accidentally pull it out, as I did. You can put the connector back in but you need to be very precise with the alignment over the 6 pins it connects to on the circuit board. I had to use a magnifying glass and it took me a few attempts.
    Fruke - Reply
  18. Sony DualSense Controller Touchpad Replacement, Remove the battery bracket: step 18, image 1 of 2 Sony DualSense Controller Touchpad Replacement, Remove the battery bracket: step 18, image 2 of 2
    • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
  19. Sony DualSense Controller Touchpad Replacement: step 19, image 1 of 2 Sony DualSense Controller Touchpad Replacement: step 19, image 2 of 2
    • Lift the battery bracket out of the motherboard.
    Black and red wires fit neatly under the lower left and lower right arms of the battery bracket, to avoid potential damage when reconnecting the rear case.
    Seomhnasaigh B - Reply
    This needs to be noted. Thanks!
    Nick Gatti -
  20. Sony DualSense Controller Touchpad Replacement, Disconnect the right trigger assembly: step 20, image 1 of 2 Sony DualSense Controller Touchpad Replacement, Disconnect the right trigger assembly: step 20, image 2 of 2
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
    • Do not completely remove the ribbon cable yet.
    If your cables are blue and in a different position, don't sweat. It's all good. Just do the same as they do and if you feel it is necessary, label with a sharpie left and right on each cable. A simple L and R works for this case
    Qbert 2030 - Reply
  21. Sony DualSense Controller Touchpad Replacement: step 21, image 1 of 2 Sony DualSense Controller Touchpad Replacement: step 21, image 2 of 2
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
    • Remove the ribbon cable.
    Depending on the revision of your controller, these ribbon cables may be slim and white and if you remove it completely, you might have to remove and tear down the trigger assembly to get the ribbon cable back in.
    Robert Borrero - Reply
    maybe I'm missing something but in this case it doesn't seem to me like these cables need to be outright removed.
    TheHooligan95 - Reply
  22. Sony DualSense Controller Touchpad Replacement, Disconnect the left trigger assembly: step 22, image 1 of 2 Sony DualSense Controller Touchpad Replacement, Disconnect the left trigger assembly: step 22, image 2 of 2
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
  23. Sony DualSense Controller Touchpad Replacement: step 23, image 1 of 2 Sony DualSense Controller Touchpad Replacement: step 23, image 2 of 2
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
  24. Sony DualSense Controller Touchpad Replacement, Disconnect the upper microphone: step 24, image 1 of 2 Sony DualSense Controller Touchpad Replacement, Disconnect the upper microphone: step 24, image 2 of 2
    • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
    what is the white thing soldered to the motherboard called where the mic ribbon cable plugs and where can i find the part?
    Abhi K - Reply
    @abhik13943 did you ever find this part?
    DaMej2895 - Reply
    unfortunately, no. i'm just using my controller without a mic.
    Abhi K -
  25. Sony DualSense Controller Touchpad Replacement, Disconnect the touchpad: step 25, image 1 of 2 Sony DualSense Controller Touchpad Replacement, Disconnect the touchpad: step 25, image 2 of 2
    • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
  26. Sony DualSense Controller Touchpad Replacement, Lift out the motherboard: step 26, image 1 of 3 Sony DualSense Controller Touchpad Replacement, Lift out the motherboard: step 26, image 2 of 3 Sony DualSense Controller Touchpad Replacement, Lift out the motherboard: step 26, image 3 of 3
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
    Pushing on the joysticks makes this much easier.
    zidek22 - Reply
    My motherboard wouldn't just lift right out. So I noticed there's also a pair of barely visible small black clips, one on each side of the motherboard, holding it down. One is right beside the battery connector and the other's directly across on the opposite side of the motherboard right beside the ribbon cable connector.
    Jason Mulholland - Reply
    Such a good observation!
    zidek22 -
    That helped a lot. If you can push those tabs it comes out a lot easier. I used my tweezers to push the left one and then as others had said pushing on the joysticks from the front of the controller makes it much easier.
    Fruke -
    Just push on the sticks. Pops out like a charm, zero effort.
    Italian Retro Guy - Reply
  27. Sony DualSense Controller Touchpad Replacement, Remove the light guide: step 27, image 1 of 2 Sony DualSense Controller Touchpad Replacement, Remove the light guide: step 27, image 2 of 2
    • Use a Phillips screwdriver to remove the two 8.5 mm screws securing the light guide.
    Mine didn't have this piece
    John - Reply
  28. Sony DualSense Controller Touchpad Replacement: step 28, image 1 of 2 Sony DualSense Controller Touchpad Replacement: step 28, image 2 of 2
    Buy
    • Use a pair of tweezers or your fingers to remove the light guide bracket.
  29. Sony DualSense Controller Touchpad Replacement: step 29, image 1 of 2 Sony DualSense Controller Touchpad Replacement: step 29, image 2 of 2
    • Use a pair of tweezers or your fingers to remove the light guide.
    Where do i buy a new light guide?
    Jasper Nuyts - Reply
  30. Sony DualSense Controller Touchpad Replacement, Remove the speaker: step 30, image 1 of 3 Sony DualSense Controller Touchpad Replacement, Remove the speaker: step 30, image 2 of 3 Sony DualSense Controller Touchpad Replacement, Remove the speaker: step 30, image 3 of 3
    Buy
    • Use a pair of tweezers to remove the speaker from the midframe.
    • Be sure to reinstall the speaker in the correct orientation with the foam pad on the left side and the gold contact points on the right.
    Speaker may be attached to the motherboard via the foam pad.
    Daniel Geppert - Reply
  31. Sony DualSense Controller Touchpad Replacement, Remove the midframe: step 31, image 1 of 2 Sony DualSense Controller Touchpad Replacement, Remove the midframe: step 31, image 2 of 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the midframe to the front case.
  32. Sony DualSense Controller Touchpad Replacement: step 32, image 1 of 3 Sony DualSense Controller Touchpad Replacement: step 32, image 2 of 3 Sony DualSense Controller Touchpad Replacement: step 32, image 3 of 3
    • Carefully lift the midframe and motherboard up and out of the front case.
    • Be careful not to strain the vibrator motor wires.
    • During reassembly, feed the touchpad's ribbon cable back through its rectangular opening in the midframe.
    Feed the ribbon cable back through the rectangular slot in the midframe during reassembly.
    Thank you for catching this!
    Sam Omiotek -
  33. Sony DualSense Controller Touchpad Replacement, Remove the touchpad: step 33, image 1 of 2 Sony DualSense Controller Touchpad Replacement, Remove the touchpad: step 33, image 2 of 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the touchpad bracket to the touchpad.
    On my early 2022 controller it only had one screw, the other side was a hook, i was able to separate them but pulling the touch pad up slightly away from the top of the controller and pushing towards the side the one screw was on.
    Ryan Hynes - Reply
    Question where can a buy a brand New touch pad replacement. I ripped mijn ribbon cable from the touch pad and cant seem to fix it please help
    patrick yard - Reply
  34. Sony DualSense Controller Touchpad Replacement: step 34, image 1 of 3 Sony DualSense Controller Touchpad Replacement: step 34, image 2 of 3 Sony DualSense Controller Touchpad Replacement: step 34, image 3 of 3
    • Lift the touchpad bracket straight up off the front case.
    • Feed the ribbon cable back through the rectangular slot in the bracket during reassembly.
    Que tipo de Flex necesito para cambiarlo?
    Betoko Rocha - Reply
    My aftermarket shell came with its own touchpad bracket. I don’t know why, especially because it has tabs on the underside going by his photo (facing the front of the controller) that prevents the touchpad from being depressed in the middle. I’m putting the OEM one back in and re-reassembling.
    George S. - Reply
  35. Sony DualSense Controller Touchpad Replacement: step 35, image 1 of 1
    • Lift the front case up off of the touchpad.
    Has anyone found a replacement logic board for trackpads?
    Bob - Reply
    not sure, but i’m currently trying to take the logic board off of my track pad, idk how to
    weston kijewski -
    My shell came with out own colored touchpad, so I needed to remove the circuit board: I rested it board side up (like in the picture) on a heating pad for a few minutes, then used a very thin plastic piece (thinner edge than the iFixit opening picks) until it was lifted enough to insert a regular pick (took another heating cycle to then insert the regular pick and lift it enough to grab the board edge with my fingers and list a little to get the top edge loose.
    George S. - Reply
11 other people completed this guide.
Sam Omiotek
83,715 Reputation
290 Guides authored
12 Comments
New touch won’t work with motherboard
Manson Knowz - Reply
Can you elaborate? I’m looking to buy one of these for this repair, and not sure which, or where
Gregg Cerenzio -
Hii, first of all big fan but i am havinf trouble finding the touchpad motherboard online to replace mine like i am talking about the whole unit cus the ribbon that is atach to mine i glued on and cant replase the ribbon so if you guys can help me find it would be a big help thx
Did you found a replacement part? I'm looking for the same thing
Julian Giraldo -
if I'm understanding correctly, you can use a hair dryer to heat up the touchpad and melt the adhesive that holds it to the board. Then do the reverse to the new touch pad.
Hope this helps!
LoudmouthdSHNK -
kasynparts have ps5 touchpad replacement parts
kasynlife - Reply
Superb guide! Allowed me to confidently dismantle the pad and get it back together again in full working order.
John Batchelor - Reply
I have different model, is there guide for the newer model?
Daz - Reply
It's worth noting, on FCC ID : A controllers the ribbon cable for the touch pad is 16 pins and not 18. When searching for parts online 18 pin seems to be the most common.
Adam wilson - Reply
I just ran into this with one of my student's PS5 controllers. I could not find the 16-pin version anywhere: every single vendor selling a "PS5 controller touchpad cable" sells the 18pin version. Fortunately, the alignment of the pins in the two cable types is exact. I took an 18-pin cable, and using an x-acto knife, straight edge, and a microscope, I was able to cut off two traces, giving a perfect replacement.
John Lasseter -
My touchpad assemblage only has a screw on the right side of the black plastic cover; the left is entirely sealed over. How do I remove it?
Local Cryptid - Reply
Newer models DO NOT allow the replacement of the touchpad cable.
You need a special cable and to desolder and resolder.
“Nice” work Sony.
Cactus - Reply
Past 24 Hours: 51
Past 7 Days: 333
Past 30 Days: 1,357
All Time: 42,411
