Sony DualSense Controller Trigger Assembly Replacement
  1. Sony DualSense Controller Trigger Assembly Replacement, Unclip the right end of the middle trim: step 1, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement, Unclip the right end of the middle trim: step 1, image 2 of 2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. Sony DualSense Controller Trigger Assembly Replacement, Unclip the lower-right edge of the middle trim: step 2, image 1 of 3 Sony DualSense Controller Trigger Assembly Replacement, Unclip the lower-right edge of the middle trim: step 2, image 2 of 3 Sony DualSense Controller Trigger Assembly Replacement, Unclip the lower-right edge of the middle trim: step 2, image 3 of 3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. Sony DualSense Controller Trigger Assembly Replacement, Unclip the left end of the middle trim: step 3, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement, Unclip the left end of the middle trim: step 3, image 2 of 2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. Sony DualSense Controller Trigger Assembly Replacement, Unclip the lower-left edge of the middle trim: step 4, image 1 of 3 Sony DualSense Controller Trigger Assembly Replacement, Unclip the lower-left edge of the middle trim: step 4, image 2 of 3 Sony DualSense Controller Trigger Assembly Replacement, Unclip the lower-left edge of the middle trim: step 4, image 3 of 3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. Sony DualSense Controller Trigger Assembly Replacement, Remove the middle trim: step 5, image 1 of 3 Sony DualSense Controller Trigger Assembly Replacement, Remove the middle trim: step 5, image 2 of 3 Sony DualSense Controller Trigger Assembly Replacement, Remove the middle trim: step 5, image 3 of 3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. Sony DualSense Controller Trigger Assembly Replacement, Remove the L1 button: step 6, image 1 of 3 Sony DualSense Controller Trigger Assembly Replacement, Remove the L1 button: step 6, image 2 of 3 Sony DualSense Controller Trigger Assembly Replacement, Remove the L1 button: step 6, image 3 of 3
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
  7. Sony DualSense Controller Trigger Assembly Replacement, Remove the R1 button: step 7, image 1 of 3 Sony DualSense Controller Trigger Assembly Replacement, Remove the R1 button: step 7, image 2 of 3 Sony DualSense Controller Trigger Assembly Replacement, Remove the R1 button: step 7, image 3 of 3
    • Repeat the previous step to remove the R1 button.
  8. Sony DualSense Controller Trigger Assembly Replacement, Remove the rear case screws: step 8, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement, Remove the rear case screws: step 8, image 2 of 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. Sony DualSense Controller Trigger Assembly Replacement: step 9, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement: step 9, image 2 of 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. Sony DualSense Controller Trigger Assembly Replacement, Separate the rear case: step 10, image 1 of 3 Sony DualSense Controller Trigger Assembly Replacement, Separate the rear case: step 10, image 2 of 3 Sony DualSense Controller Trigger Assembly Replacement, Separate the rear case: step 10, image 3 of 3
    • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
  11. Sony DualSense Controller Trigger Assembly Replacement: step 11, image 1 of 3 Sony DualSense Controller Trigger Assembly Replacement: step 11, image 2 of 3 Sony DualSense Controller Trigger Assembly Replacement: step 11, image 3 of 3
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
  12. Sony DualSense Controller Trigger Assembly Replacement: step 12, image 1 of 3 Sony DualSense Controller Trigger Assembly Replacement: step 12, image 2 of 3 Sony DualSense Controller Trigger Assembly Replacement: step 12, image 3 of 3
    • Repeat the previous step on the right edge to release its clips.
  13. Sony DualSense Controller Trigger Assembly Replacement: step 13, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement: step 13, image 2 of 2
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
  14. Sony DualSense Controller Trigger Assembly Replacement, Remove the rear case: step 14, image 1 of 1
    • Remove the rear case.
  15. Sony DualSense Controller Trigger Assembly Replacement, Disconnect the battery: step 15, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement, Disconnect the battery: step 15, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Grip the connector, not the wires, when disconnecting.
  16. Sony DualSense Controller Trigger Assembly Replacement, Remove the battery: step 16, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement, Remove the battery: step 16, image 2 of 2
    • Lift the battery straight out of the battery bracket.
  17. Sony DualSense Controller Trigger Assembly Replacement, Remove the lower microphone: step 17, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement, Remove the lower microphone: step 17, image 2 of 2
    Buy
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
  18. Sony DualSense Controller Trigger Assembly Replacement, Remove the battery bracket: step 18, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement, Remove the battery bracket: step 18, image 2 of 2
    • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
  19. Sony DualSense Controller Trigger Assembly Replacement: step 19, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement: step 19, image 2 of 2
    • Lift the battery bracket out of the motherboard.
  20. Sony DualSense Controller Trigger Assembly Replacement, Disconnect the right trigger assembly: step 20, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement, Disconnect the right trigger assembly: step 20, image 2 of 2
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
    • Do not completely remove the ribbon cable yet.
  21. Sony DualSense Controller Trigger Assembly Replacement: step 21, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement: step 21, image 2 of 2
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
    • Remove the ribbon cable.
  22. Sony DualSense Controller Trigger Assembly Replacement, Disconnect the left trigger assembly: step 22, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement, Disconnect the left trigger assembly: step 22, image 2 of 2
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
  23. Sony DualSense Controller Trigger Assembly Replacement: step 23, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement: step 23, image 2 of 2
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
  24. Sony DualSense Controller Trigger Assembly Replacement, Disconnect the upper microphone: step 24, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement, Disconnect the upper microphone: step 24, image 2 of 2
    • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
  25. Sony DualSense Controller Trigger Assembly Replacement, Disconnect the touchpad: step 25, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement, Disconnect the touchpad: step 25, image 2 of 2
    • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
  26. Sony DualSense Controller Trigger Assembly Replacement, Lift out the motherboard: step 26, image 1 of 3 Sony DualSense Controller Trigger Assembly Replacement, Lift out the motherboard: step 26, image 2 of 3 Sony DualSense Controller Trigger Assembly Replacement, Lift out the motherboard: step 26, image 3 of 3
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints.
    • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
  27. Sony DualSense Controller Trigger Assembly Replacement, Remove the light guide: step 27, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement, Remove the light guide: step 27, image 2 of 2
    • Use a Phillips screwdriver to remove the two 8.5 mm screws securing the light guide.
  28. Sony DualSense Controller Trigger Assembly Replacement: step 28, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement: step 28, image 2 of 2
    Buy
    • Use a pair of tweezers or your fingers to remove the light guide bracket.
  29. Sony DualSense Controller Trigger Assembly Replacement: step 29, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement: step 29, image 2 of 2
    • Use a pair of tweezers or your fingers to remove the light guide.
  30. Sony DualSense Controller Trigger Assembly Replacement, Remove the speaker: step 30, image 1 of 3 Sony DualSense Controller Trigger Assembly Replacement, Remove the speaker: step 30, image 2 of 3 Sony DualSense Controller Trigger Assembly Replacement, Remove the speaker: step 30, image 3 of 3
    Buy
    • Use a pair of tweezers to remove the speaker from the midframe.
    • Be sure to reinstall the speaker in the correct orientation with the foam pad on the left side and the gold contact points on the right.
  31. Sony DualSense Controller Trigger Assembly Replacement, Remove the midframe: step 31, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement, Remove the midframe: step 31, image 2 of 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the midframe to the front case.
  32. Sony DualSense Controller Trigger Assembly Replacement: step 32, image 1 of 3 Sony DualSense Controller Trigger Assembly Replacement: step 32, image 2 of 3 Sony DualSense Controller Trigger Assembly Replacement: step 32, image 3 of 3
    • Carefully lift the midframe and motherboard up and out of the front case.
    • Be careful not to strain the vibrator motor wires.
    • During reassembly, feed the touchpad's ribbon cable back through its rectangular opening in the midframe.
  33. Sony DualSense Controller Trigger Assembly Replacement, Remove the trigger assemblies: step 33, image 1 of 2 Sony DualSense Controller Trigger Assembly Replacement, Remove the trigger assemblies: step 33, image 2 of 2
    • Flip over the midframe and motherboard.
    • Use a Phillips screwdriver to remove the four 6.4 mm screws securing the trigger assemblies to the midframe.
    • If only one trigger assembly needs to be replaced, only remove the screws for that one.
  34. Sony DualSense Controller Trigger Assembly Replacement: step 34, image 1 of 3 Sony DualSense Controller Trigger Assembly Replacement: step 34, image 2 of 3 Sony DualSense Controller Trigger Assembly Replacement: step 34, image 3 of 3
    • Carefully flip the midframe and motherboard over.
    • The trigger assemblies are loose and may fall out.
    • Remove the trigger assemblies.
26 other people completed this guide.
Sam Omiotek
93,481 Reputation
290 Guides authored
21 Guide Comments
So after I completed this my L1 stopped working how do I fix that? Lol the L2 R1 and R2 work fine
Chris Doyle - Reply
i know this is pretty long after you posted but could you tell me where you found the spare part?
Christos -
Ali express has everything since after warranty sony won't even look at your machine. Even for profit. Usbc port on the controller has no strength and I've had 2 go and that was from gentle use when I only had one controller then the second one did it so I had to buy 2 at once.
Joey Strong -
How do I find these parts? I’ve looked online for ps5 trigger assemblies and I can’t find them.
Avonlea - Reply
hello. did you find the trigger spare part assemblies? I am also looking for it but unfortunately couldn't find them yet.
Sezer Metin -
Past 24 Hours: 145
Past 7 Days: 1,079
Past 30 Days: 3,953
All Time: 89,099
