Asus ZenFone 3 Zoom Screen Replacement
Luke Theiss
Luke Theiss and 4 other contributors
Last updated on May 7, 2024
20 - 50 minutes
Difficult
Introduction
Go to step 1
This guide is designed to show how to safely remove the screen, on the Asus ZenFone Zoom 3, for replacement. You will need to take the back off the phone, as well as stripping off the housings one by one. You will need a soldering iron. Using tools, such as the soldering iron, can be dangerous so make sure you use proper precautions and follow this guide if you are unfamiliar with soldering. You will also want to be careful with how you move around the perimeter of the phone, removing the screen, so you don’t damage the screen or worse, break the casing.
Tools
Show more…
  1. Asus ZenFone 3 Zoom Screen Replacement, Screen Replacement: step 1, image 1 of 2 Asus ZenFone 3 Zoom Screen Replacement, Screen Replacement: step 1, image 2 of 2
    • Use sim card attachment for the screwdriver found in the IFIXIT box to remove the sim card tray from the phone.
  2. Asus ZenFone 3 Zoom Screen Replacement: step 2, image 1 of 1
    • Remove the 3.5 mm screws on both sides of the charging port, at the bottom of the phone, using the T2 screwdriver.
  3. Asus ZenFone 3 Zoom Screen Replacement: step 3, image 1 of 2 Asus ZenFone 3 Zoom Screen Replacement: step 3, image 2 of 2
    • Use the opening tool to separate the screen and the plastic body of the phone.
  4. Asus ZenFone 3 Zoom Screen Replacement: step 4, image 1 of 1
    • Utilize the PH #00 attachment to remove the two 3.3 mm screws in the bracket to the top left of the battery.
  5. Asus ZenFone 3 Zoom Screen Replacement: step 5, image 1 of 1
    • After removing the bracket and screws, pull up on the battery from the bottom of the unit and set aside.
  6. Asus ZenFone 3 Zoom Screen Replacement: step 6, image 1 of 2 Asus ZenFone 3 Zoom Screen Replacement: step 6, image 2 of 2
    • Remove all three screws near the top of the phone with the PH #00.
    • The top right and left screws are 3.25 mm.
    • The middle screw is 2.65 mm.
  7. Asus ZenFone 3 Zoom Screen Replacement: step 7, image 1 of 1
    • De-solder the single black speaker wire attached on the left side of the phone.
  8. Asus ZenFone 3 Zoom Screen Replacement: step 8, image 1 of 2 Asus ZenFone 3 Zoom Screen Replacement: step 8, image 2 of 2
    • Use the flat-edge side of iFixIt plastic spudger to detach both of the ribbon cables off of the motherboard at their connection point.
  9. Asus ZenFone 3 Zoom Screen Replacement: step 9, image 1 of 2 Asus ZenFone 3 Zoom Screen Replacement: step 9, image 2 of 2
    Tool used on this step:
    • Use the tweezers to lift up on the edges of the motherboard located above where the battery was, then remove the motherboard.
  10. Asus ZenFone 3 Zoom Screen Replacement: step 10, image 1 of 2 Asus ZenFone 3 Zoom Screen Replacement: step 10, image 2 of 2
    • Remove the speaker cover at the bottom of the casing by taking out all five 3.25 mm screws with the PH #00.
  11. Asus ZenFone 3 Zoom Screen Replacement: step 11, image 1 of 1
    • Gently pry off the ribbon cable from speaker housing with the flat-edge side of the iFixit plastic spudger.
  12. Asus ZenFone 3 Zoom Screen Replacement: step 12, image 1 of 1
    • Remove the speaker once exposed.
  13. Asus ZenFone 3 Zoom Screen Replacement: step 13, image 1 of 1
    • Use iOpener to soften the adhesive keeping the screen on the device.
  14. Asus ZenFone 3 Zoom Screen Replacement: step 14, image 1 of 1
    • Pry off the screen beginning at the right-hand side toward the bottom of the phone with the plastic flat-edge spudger.
  15. Asus ZenFone 3 Zoom Screen Replacement: step 15, image 1 of 1
    • Progress around the perimeter of the phone with the pry tool till the screen is off.
  16. Asus ZenFone 3 Zoom Screen Replacement: step 16, image 1 of 2 Asus ZenFone 3 Zoom Screen Replacement: step 16, image 2 of 2
    • Remove the screen by pulling the attached ribbon cable out through the exposed opening.
  17. Asus ZenFone 3 Zoom Screen Replacement: step 17, image 1 of 1
    • The finished product will be a screen with nothing attached to the body of the phone.
Finish Line
Luke Theiss
271 Reputation
1 Guide authored
IUPUI, Team S2-G3, Harley Summer 2019 Member of IUPUI, Team S2-G3, Harley Summer 2019
IUPUI-HARLEY-SU19S2G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 2,628
