Sony ECM-MS907 Microphone Disassembly
  1. Sony ECM-MS907 Microphone Disassembly, Microphone: step 1, image 1 of 1
    • Using the Phillips #00 screwdriver, remove the screw securing diaphragm to the base of the microphone.
  2. Sony ECM-MS907 Microphone Disassembly: step 2, image 1 of 2 Sony ECM-MS907 Microphone Disassembly: step 2, image 2 of 2
    • Separate the microphone into two pieces to reveal the internal shield cover.
  3. Sony ECM-MS907 Microphone Disassembly: step 3, image 1 of 1
    • Unscrew the base of the microphone in a clockwise motion and separate the bottom and top of the microphone.
  4. Sony ECM-MS907 Microphone Disassembly: step 4, image 1 of 1
    • Using a Phillips #2 screwdriver, remove the screw directly above the battery.
  5. Sony ECM-MS907 Microphone Disassembly: step 5, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the black screw near the bottom of the microphone.
  6. Sony ECM-MS907 Microphone Disassembly: step 6, image 1 of 3 Sony ECM-MS907 Microphone Disassembly: step 6, image 2 of 3 Sony ECM-MS907 Microphone Disassembly: step 6, image 3 of 3
    Tool used on this step:
    Heavy-Duty Spudger
    Buy
Attached Documents
Kefaya
364 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 33
All Time: 5,904
