Sony Ericsson K750i LCD Screen Replacement
  1. Sony Ericsson K750i LCD Screen Replacement, Battery Cover: step 1, image 1 of 1
    • Remove the battery cover.
    • Press down firmly with your thumb and slide the cover back.
  2. Sony Ericsson K750i LCD Screen Replacement, Back Casing: step 2, image 1 of 1
    • Remove two Phillips #0 screws from the battery chamber.
    • Remove two Torx T6 screws from the battery chamber.
  3. Sony Ericsson K750i LCD Screen Replacement: step 3, image 1 of 1
    • Gently pry off the back casing.
    • Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
  4. Sony Ericsson K750i LCD Screen Replacement: step 4, image 1 of 1
    • Remove the casing to expose the camera's components.
  5. Sony Ericsson K750i LCD Screen Replacement, Keypad: step 5, image 1 of 1
    • Gently pry open the front casing by working an opening tool along the entire seam.
  6. Sony Ericsson K750i LCD Screen Replacement: step 6, image 1 of 1
    • Remove the front casing by gently lifting it from the phone.
    • Be careful not to pull off any other delicate pieces.
  7. Sony Ericsson K750i LCD Screen Replacement: step 7, image 1 of 2 Sony Ericsson K750i LCD Screen Replacement: step 7, image 2 of 2
    • Remove the keypad.
    • The LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
  8. Sony Ericsson K750i LCD Screen Replacement, LCD Screen: step 8, image 1 of 1
    • Remove the screws holding the screen in place.
  9. Sony Ericsson K750i LCD Screen Replacement: step 9, image 1 of 1
    • Gently lift the base of the keypad to remove it.
  10. Sony Ericsson K750i LCD Screen Replacement: step 10, image 1 of 1
    • Gently pull up the green film, avoiding the joystick.
    • The LCD screen will be attached to this film and come off with it.
Abby Evers
202 Reputation
6 Guides authored
UW Stout, Team 1-6, Zhou Fall 2011 Member of UW Stout, Team 1-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G6
4 Members
12 Guides authored
One Comment
Works perfectly, thank you guys!
Aurelien - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 4,070
