Sony Ericsson QuickShare T630 Screen Replacement
  1. Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Phone Enclosure: step 1, image 1 of 1
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Sony Ericsson QuickShare T630 Screen Replacement: step 2, image 1 of 2 Sony Ericsson QuickShare T630 Screen Replacement: step 2, image 2 of 2
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Sony Ericsson QuickShare T630 Screen Replacement: step 3, image 1 of 1
    • Slide the battery upward to remove.
  4. Sony Ericsson QuickShare T630 Screen Replacement: step 4, image 1 of 2 Sony Ericsson QuickShare T630 Screen Replacement: step 4, image 2 of 2
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. Sony Ericsson QuickShare T630 Screen Replacement: step 5, image 1 of 2 Sony Ericsson QuickShare T630 Screen Replacement: step 5, image 2 of 2
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. Sony Ericsson QuickShare T630 Screen Replacement: step 6, image 1 of 1
    • Slide the aerial upward to remove it.
  7. Sony Ericsson QuickShare T630 Screen Replacement: step 7, image 1 of 2 Sony Ericsson QuickShare T630 Screen Replacement: step 7, image 2 of 2
    • Remove the four screws located at each corner of the device.
  8. Sony Ericsson QuickShare T630 Screen Replacement: step 8, image 1 of 2 Sony Ericsson QuickShare T630 Screen Replacement: step 8, image 2 of 2
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. Sony Ericsson QuickShare T630 Screen Replacement: step 9, image 1 of 3 Sony Ericsson QuickShare T630 Screen Replacement: step 9, image 2 of 3 Sony Ericsson QuickShare T630 Screen Replacement: step 9, image 3 of 3
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
  10. Sony Ericsson QuickShare T630 Screen Replacement: step 10, image 1 of 3 Sony Ericsson QuickShare T630 Screen Replacement: step 10, image 2 of 3 Sony Ericsson QuickShare T630 Screen Replacement: step 10, image 3 of 3
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
  11. Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: step 11, image 1 of 3 Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: step 11, image 2 of 3 Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: step 11, image 3 of 3
    • To place a new screen, slide the green ribbon connector into the ribbon clamp that the defective screen was pulled from.
Jeremy
181 Reputation
1 Guide authored
1 Guide Comment
Worked well until the screen replacemet - ribbon cable would not go into clamp - phone plus new screen straight in the bin - a little gutted - but hey it was an old but loved phone.
roger hiley - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 29
All Time: 1,626
