Sony Ericsson T68i Keypad Replacement
  1. Sony Ericsson T68i Keypad Replacement, Keypad: step 1, image 1 of 2 Sony Ericsson T68i Keypad Replacement, Keypad: step 1, image 2 of 2
    • Remove the battery from the back.
  2. Sony Ericsson T68i Keypad Replacement: step 2, image 1 of 3 Sony Ericsson T68i Keypad Replacement: step 2, image 2 of 3 Sony Ericsson T68i Keypad Replacement: step 2, image 3 of 3
    • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
    • Do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Sony Ericsson T68i Keypad Replacement: step 3, image 1 of 3 Sony Ericsson T68i Keypad Replacement: step 3, image 2 of 3 Sony Ericsson T68i Keypad Replacement: step 3, image 3 of 3
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  4. Sony Ericsson T68i Keypad Replacement: step 4, image 1 of 3 Sony Ericsson T68i Keypad Replacement: step 4, image 2 of 3 Sony Ericsson T68i Keypad Replacement: step 4, image 3 of 3
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
Tim Dascomb
174 Reputation
7 Guides authored
Cal Poly, Team 26-34, Regan Spring 2010 Member of Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 Members
13 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 43
All Time: 2,314
