Sony Ericsson TM506 Sim Card Replacement
  1. Sony Ericsson TM506 Sim Card Replacement, Battery Cover: step 1, image 1 of 3 Sony Ericsson TM506 Sim Card Replacement, Battery Cover: step 1, image 2 of 3 Sony Ericsson TM506 Sim Card Replacement, Battery Cover: step 1, image 3 of 3
    • Firmly hold the phone between your fingers with your thumb on the battery cover.
    • Push down with your thumb until the battery cover comes off.
  2. Sony Ericsson TM506 Sim Card Replacement, Back Case: step 2, image 1 of 3 Sony Ericsson TM506 Sim Card Replacement, Back Case: step 2, image 2 of 3 Sony Ericsson TM506 Sim Card Replacement, Back Case: step 2, image 3 of 3
    • Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver.
  3. Sony Ericsson TM506 Sim Card Replacement: step 3, image 1 of 2 Sony Ericsson TM506 Sim Card Replacement: step 3, image 2 of 2
    • Remove the two rubber casings for the top two screws with a plastic opening tool.
  4. Sony Ericsson TM506 Sim Card Replacement: step 4, image 1 of 1
    • Unscrew these two 5.4mm screws with a Torx T6 screwdriver.
  5. Sony Ericsson TM506 Sim Card Replacement: step 5, image 1 of 3 Sony Ericsson TM506 Sim Card Replacement: step 5, image 2 of 3 Sony Ericsson TM506 Sim Card Replacement: step 5, image 3 of 3
    • There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case.
  6. Sony Ericsson TM506 Sim Card Replacement, Sim Card: step 6, image 1 of 2 Sony Ericsson TM506 Sim Card Replacement, Sim Card: step 6, image 2 of 2
    • The Sim card can simply be pulled out through the opening.
Daniel
83 Reputation
7 Guides authored
Cal Poly, Team 1-1, Regan SU 2012 Member of Cal Poly, Team 1-1, Regan SU 2012
CPSU-REGAN-SU12S1G1
2 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 52
All Time: 1,672
