Sony Ericsson W580i LCD Replacement
  1. Sony Ericsson W580i LCD Replacement, Front Cover: step 1, image 1 of 2 Sony Ericsson W580i LCD Replacement, Front Cover: step 1, image 2 of 2
    • Insert the edge of an opening tool between the front cover and the phone.
    • Gently pry off the front cover working your way around the edges.
  2. Sony Ericsson W580i LCD Replacement: step 2, image 1 of 2 Sony Ericsson W580i LCD Replacement: step 2, image 2 of 2
    • Pull the front cover down and away from the phone.
    • The front keypads might come off with the front cover. Do not lose these.
  3. Sony Ericsson W580i LCD Replacement: step 3, image 1 of 1
    • Gently peel the keypad away from the phone.
  4. Sony Ericsson W580i LCD Replacement, LCD: step 4, image 1 of 2 Sony Ericsson W580i LCD Replacement, LCD: step 4, image 2 of 2
    • Insert a spudger between the lower edge of the screen and the phone.
    • Pry the screen up to disconnect the tabs on each side holding the screen in.
    • Do not remove the screen yet. There is a ribbon connecting the screen to the motherboard.
  5. Sony Ericsson W580i LCD Replacement: step 5, image 1 of 2 Sony Ericsson W580i LCD Replacement: step 5, image 2 of 2
    • Use a spudger to remove the ribbon cable from the motherboard.
    • Lift the screen away from the phone
6 other people completed this guide.
Diego
388 Reputation
4 Guides authored
Cal Poly, Team 5-31, Amido Fall 2011 Member of Cal Poly, Team 5-31, Amido Fall 2011
CPSU-AMIDO-F11S5G31
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 5,665
