Sony Ericsson Xperia Play LCD Display Replacement
Video Overview
  1. Sony Ericsson Xperia Play LCD Display Replacement, LCD Display: step 1, image 1 of 3 Sony Ericsson Xperia Play LCD Display Replacement, LCD Display: step 1, image 2 of 3 Sony Ericsson Xperia Play LCD Display Replacement, LCD Display: step 1, image 3 of 3
    • Remove the battery cover and the battery.
    • You have the 6x silver screws and 7x black screws and you can remove the rear bezel.
  2. Sony Ericsson Xperia Play LCD Display Replacement: step 2, image 1 of 3 Sony Ericsson Xperia Play LCD Display Replacement: step 2, image 2 of 3 Sony Ericsson Xperia Play LCD Display Replacement: step 2, image 3 of 3
    • By using a plastic tool, disconnect the main flex cable connector. Be careful, near to the connector there are many small elements.
    • Disconnect the gaming keyboard flex cable.
  3. Sony Ericsson Xperia Play LCD Display Replacement: step 3, image 1 of 2 Sony Ericsson Xperia Play LCD Display Replacement: step 3, image 2 of 2
    • Remove the motherboard and the gaming keyboard.
  4. Sony Ericsson Xperia Play LCD Display Replacement: step 4, image 1 of 3 Sony Ericsson Xperia Play LCD Display Replacement: step 4, image 2 of 3 Sony Ericsson Xperia Play LCD Display Replacement: step 4, image 3 of 3
    • Unscrew the 4x black screws.
    • Remove the black sticker on the corner and disconnect the touchscreen flex cable.
    • Disassemble front bezel.
  5. Sony Ericsson Xperia Play LCD Display Replacement: step 5, image 1 of 3 Sony Ericsson Xperia Play LCD Display Replacement: step 5, image 2 of 3 Sony Ericsson Xperia Play LCD Display Replacement: step 5, image 3 of 3
    • Use the thin side of a plastic tool to separate the LCD display from the base bezel.
    • Now you are ready to install the new spare part.
    • I prefer to test the new spare part before the full assembly.
  6. Sony Ericsson Xperia Play LCD Display Replacement: step 6, image 1 of 1
3 other people completed this guide.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
One Comment
Do you have a datasheet for the display? I wanted to reuse it but i cannot find the function of the pins.
jp r - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 35
All Time: 5,104
