Sony Ericsson Xperia Play Main Flex Cable Replacement
Video Overview
  1. Sony Ericsson Xperia Play Main Flex Cable Replacement, Main Flex Ribbon Cable: step 1, image 1 of 3 Sony Ericsson Xperia Play Main Flex Cable Replacement, Main Flex Ribbon Cable: step 1, image 2 of 3 Sony Ericsson Xperia Play Main Flex Cable Replacement, Main Flex Ribbon Cable: step 1, image 3 of 3
    • Remove the battery cover and the battery.
    • You have 6x silver screw and 7x black screw and remove the rear bezel.
  2. Sony Ericsson Xperia Play Main Flex Cable Replacement: step 2, image 1 of 2 Sony Ericsson Xperia Play Main Flex Cable Replacement: step 2, image 2 of 2
    • Now with a plastic tool disconnect the main flex cable. Be careful, near to the main flex cable connector there is many small elements.
    • Disconnect the gaming keyboard flex keyboard.
  3. Sony Ericsson Xperia Play Main Flex Cable Replacement: step 3, image 1 of 2 Sony Ericsson Xperia Play Main Flex Cable Replacement: step 3, image 2 of 2
    • Remove the mother board and the gaming keyboard.
  4. Sony Ericsson Xperia Play Main Flex Cable Replacement: step 4, image 1 of 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: step 4, image 2 of 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: step 4, image 3 of 3
    • Unscrew the 4x screws.
    • Remove the black sticker.
    • Disconnect the touchscreen flex cable connector.
    • Now you can disassemble the front bezel.
  5. Sony Ericsson Xperia Play Main Flex Cable Replacement: step 5, image 1 of 2 Sony Ericsson Xperia Play Main Flex Cable Replacement: step 5, image 2 of 2
    • Use the thin end of a plastic tool to remove LCD Display and disconnect the flex cable.
  6. Sony Ericsson Xperia Play Main Flex Cable Replacement: step 6, image 1 of 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: step 6, image 2 of 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: step 6, image 3 of 3
    • To release the ribbon cable peel off two patches.
  7. Sony Ericsson Xperia Play Main Flex Cable Replacement: step 7, image 1 of 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: step 7, image 2 of 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: step 7, image 3 of 3
    • Now remove the small metal plate taped to the flex cable.
    • Remove the plastic plate from the back side of the flex cable connector.
    • Bend the cable at an angle so you can push it down through the hole.
  8. Sony Ericsson Xperia Play Main Flex Cable Replacement: step 8, image 1 of 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: step 8, image 2 of 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: step 8, image 3 of 3
    • Use the same technique when you are installing the new Main Ribbon Cable.
    • I prefer to test the new spare part before the full assembly.
  9. Sony Ericsson Xperia Play Main Flex Cable Replacement: step 9, image 1 of 1
5 other people completed this guide.
ZFix
191,882 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,516 Guides authored
3 Comments
Iv got a problem my phone won't turn on or charge but when i plug the charger in the power button just flashes red a couple of times then nothing do u know what this means is it the battery or the phone that is broke
paulfrost412 - Reply
Is "small metal plate" from Step 7 important? Forgot to put it inside and if there is no need to open it again (everything works) I won't do it :)
ch3mn3y - Reply
vreau sa cumpar sleif la xperia play, rog foarte muld daca aveti ceva informatii sunati sau scrieti pe mob; 060215747.
petrea - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 37
All Time: 7,503
